1985 4+3 Manual
Old Nov 4, 2022 | 07:41 AM
peyc2's Avatar
peyc2
The drain plug idea looks great. did he say he got the plug at Harbor Freight, or an auto parts store?
I think I am going to try to do it when i drop the OD pan as my next adventure.
I got the fluid, just waiting on the pan gasket to arrive.
also, should I use RTV on both sides, the pan to gasket, and the gasket to trans? and which RTV is best?
thanks for all the help I appreciate it.
Old Nov 14, 2022 | 08:59 AM
2011KLR's Avatar
2011KLR
Default DNE 4+3 Fluid r&r
While you have the drain pan off of the OD, id suggest flushing the cooler lines too. I think what i used was called Kooler Kleener.
sre
Old Nov 14, 2022 | 09:29 AM
jdjenk's Avatar
jdjenk
I just put RTV on the top of the gasket where it meets the pan. After putting it on, tightening, and filling, I didn't use the trans and let it sit overnight. Doesn't leak at all.
Old Nov 25, 2022 | 09:09 AM
NickPSI's Avatar
NickPSI
If you decide to rebuild the 4+3, don't use a paper gasket when mating the OD to the t10, learned that the hard way. Just rtv it.
Old Nov 25, 2022 | 02:44 PM
johnfin's Avatar
johnfin
What are the oil levels (qty) for each section, auto and manual?
Old Nov 25, 2022 | 02:50 PM
NickPSI's Avatar
NickPSI
I know the t10 is fill until it comes back out the fill hole on level ground and the OD is the same? I don't remember for the OD.
T10 is definitely fill until it comes back at you. And be sure to use the GL4 specific oil for that trans, I used sta lube GL4.
Old Nov 26, 2022 | 11:47 AM
johnfin's Avatar
johnfin
Makes it kinda hard to buy the right amount of oil not knowing the volume. Having it come out of the fill hole is not accurate enough.
Old Nov 26, 2022 | 12:02 PM
NickPSI's Avatar
NickPSI
Buy 3 quarts of atf and 2 quarts of GL4.
Old Nov 28, 2022 | 04:28 PM
johnfin's Avatar
johnfin
My 85 owners manual calls out for 80WGL5. Why do you recommend GL4?
Old Nov 28, 2022 | 05:41 PM
NickPSI's Avatar
NickPSI
I'll be honest with you, I have never read the owners manual for my 85. That's interesting.
However, if you Google "what gear oil for a super t10" every single forum and article that comes up says stay away from gl5 for a t10 or super t10.
Old Nov 28, 2022 | 07:07 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by IHBD
If I had to select a current lube for the 4-speed in my 85 I'd probably use the GM Syncromesh Fluid. It has been fabulous in my 90 so I put it in the 92 as well. It is certainly "approved" for yellow metals.
I don't know that the use of what you mention to be a 'desired' use! All bearings in the T10 and other (similar) are 'ball' with the exception of the counter-shaft and the ZF is Metric 'needle roller'. Caged ball and tapered cone/race I believe have different requirements. 'Yellow Metals' have nothing to do with it. I do understand your mention of 'Yellow Metals'! I believe currently many use and suggest GL4 85W90 and NEVER 85W90 that has the additive for 'differential clutch-packs'. Newer GL5 so long as it's MT1 approved is mentioned often also. All lubricants have certainly changed through the years.
