91 Condenser Upgrade to Parallel Flow
Old Oct 25, 2022 | 09:20 PM
dailo's Avatar
dailo
Default 91 Condenser Upgrade to Parallel Flow
Hi
I’ve switched to 134 and have been running the old condenser style but it’s really not enough to keep up with the heat in Hong Kong. I’ve had a bit of a leak in the condenser so decided to try the upgraded style.
Has anyone successfully fit a newer style condenser to a 90/91/92/93?
If so could you please share how you fit it in?
The newer style is a bit smaller and has different mounting points.
Thank you!
Old Oct 26, 2022 | 02:27 AM
Deepa's Avatar
Deepa
Be careful. The threads are different on the later condenser. They switched over to metric.
