Acc. will not turn on.
Old Jan 9, 2003 | 11:24 PM
vetteguy216's Avatar
vetteguy216
Default Acc. will not turn on.
Iginition will start car with no problem but when turned back for Acc. it will not move at all. Do you guys know what is wrong with it?
Old Jan 10, 2003 | 10:13 AM
Barrier's Avatar
Barrier
Default Re: Acc. will not turn on. (vetteguy216)
My '86 did the same thing. I would keep trying everytime I remembered and eventually it started working. It works fine now. I think it probably was not used very often and kind of stuck when turned back towards Acc.
Barrier :p: :)
Old Jan 10, 2003 | 10:15 AM
Barrier's Avatar
Barrier
One more thing you have to push the key in while turning, and wiggle a bit.
Barrier
Old Jan 10, 2003 | 12:37 PM
smittyvette57's Avatar
smittyvette57
Try some graphite in the cylinder where the key goes and contiue trying it. I had to take mine out to get it to work. Beware if you have to take out. You need a steering wheel puller, plate depresser, and to note the telescope adjuster orientation. You also have to get behind the direction/highbeam switch, patience. One torx or allen screw holds it in becareful not pinch the vats wire also
To Acc. will not turn on.
