94 corvett3 no brights
Old Dec 10, 2022 | 08:05 PM
lt1with_balls's Avatar
lt1with_balls
Default 94 corvett3 no brights
94 corvette no brights. The handle is loose and doesn’t even click. So my question is there a video or tutorial on how t9 fix?
I was also think universal external brights kit.
lemme know guys
Old Dec 10, 2022 | 08:23 PM
arbee's Avatar
arbee
lemme know guys
Sorry Hoss but you get nothing from me. Others can judge for themselves. This is about the 15th thread you have started in a month. That's one every two days. Each one has a supposed problem that you are asking advise on. Good tips have been given and you have reported back ZERO times. NO follow-up to report on what you have accomplished. Two of us have called you out now. Stop it! Find some other entertainment. Future threads of yours will be ignored by many of us.
Old Dec 10, 2022 | 09:58 PM
lt1with_balls
Isn’t that what forums are for? Help? Wtf is your problem. Be nice. Arbee’s….
yours the only guy that is being rude everyone else is helpful.
QUOTE=arbee;1606013353]Sorry Hoss but you get nothing from me. Others can judge for
themselves. This is about the 15th thread you have started in a month. That's one every two days. Each one has a supposed problem that you are asking advise on. Good tips have been given and you have reported back ZERO times. NO follow-up to report on what you have accomplished. Two of us have called you out now. Stop it! Find some other entertainment. Future threads of yours will be ignored by many of us.[/QUOTE]
Old Dec 10, 2022 | 10:09 PM
lt1with_balls
Also…. It’s helpful to others with the same issue… so think on the bright side
QUOTE=arbee;1606013353]Sorry Hoss but you get nothing from me. Others can judge for themselves. This is about the 15th thread you have started in a month. That's one every two days. Each one has a supposed problem that you are asking advise on. Good tips have been given and you have reported back ZERO times. NO follow-up to report on what you have accomplished. Two of us have called you out now. Stop it! Find some other entertainment. Future threads of yours will be ignored by many of us.[/QUOTE]
Old Dec 11, 2022 | 08:42 AM
vetteLT193's Avatar
vetteLT193
It is NOT helpful when you never post a final resolution. Based on your posts your car still doesn't even run
Old Dec 11, 2022 | 02:33 PM
lt1with_balls
well sorry mr I’m on Arbee’s “ we have the meats” side. I will start posting resolutions then. Shiiiit!
Old Dec 12, 2022 | 12:47 AM
lt1with_balls
LOOK I’m usually not an ******* but all I want to do it fix my ******* BRIGHTS? Someone here nicer should be healthful enough to chime in. Y’all need to take Xanax chill tf out … being negative makes you old faster… I plan on being a happy grandpa
QUOTE=lt1with_balls;1606013299]94 corvette no brights. The handle is loose and doesn’t even click. So my question is there a video or tutorial on how t9 fix?
lemme know guys[/QUOTE]
Old Dec 13, 2022 | 06:46 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
The problem here is that you are indeed coming off as an *** particularly with your latest comments .............. and Arbee is correct if you continue to act this way many of the more knowledgeable folks will just start ignoring your posts.
Perhaps you are not familiar with forums such as this one BUT ....... your posting multiple problems and never ever coming back with results of the suggestions that you have tried ...... helps NO ONE.
Just letting you know .....
Old Dec 13, 2022 | 07:21 PM
lt1with_balls
Thanks for your your input mr pissbody. You are correct… I’m am an ******* but someone has to be… look I’m gonna start posting results as soon as I get time but I’m a multi tasker and forget a lot so yeah.. cheers mate
Old Dec 14, 2022 | 12:18 PM
s carter's Avatar
s carter
OK now lets get down to the problem, No Click, No High Beam odds are you have a problem with the Actuator Slide either broken or misaligned. so start with pulling knee kick panel and verify you do or don't have movement of the rod at the switch. If you have movement either adjust switch or replace it, if Not take the cover plate off below the Directional lever and disassemble the plate that covers the slide (be warned it Will pretty much fall apart and need to be reassembled) but it is the only way to tell if finger broke off from lever or the slide broke or if the rod slide past the Actuator slide.
https://corvetteparts.com/item/actua...lide-1990-1996
Old Dec 14, 2022 | 08:42 PM
jrobin1's Avatar
jrobin1
The switch has slotted holes and after 20-30 years can become loose and slide out of range of the actuator stem. If that is the case, simply loosen the screws a little more, slide the switch up toward the steering wheel, test for operation. if successful tighten screws and button the rest of the job up.
To 94 corvett3 no brights
