manual conversion for an 87 c4
Old Dec 17, 2022 | 06:37 AM
confused.but.driven's Avatar
confused.but.driven
Cruising
Default manual conversion for an 87 c4
i want to convert my automatic 87 c4 corvette to a manual transmission.
i know i need a flywheel, clutch, bellhousing, transmission, shifter, clutch linkages, and pivot shaft (i can also fabricate a mount or two)
my problem is that i do not know what specific parts (brands, or models) of these parts i should buy for my case
what transmission would be good, or what pedal assembly should i get and where?
if you have any knowledge in this field please help
i would also like to stay under 2k for it if possible
Old Dec 17, 2022 | 04:18 PM
MrBigDee's Avatar
MrBigDee
Here is my project where I changed the automatic to manual.
ZF is the best solution and Dana 44 rear end. Clutch with your need, I wanted 1000 hp from the clutch.
https://www.corvetteforum.com/forums...gine-mods.html
Old Dec 22, 2022 | 01:43 AM
confused.but.driven
Cruising
how much did the build cost?
Old Dec 22, 2022 | 03:21 PM
MrBigDee's Avatar
MrBigDee
I did the installation myself, so there was no price for the work.
-ZF 6 speed, C beam, piece of cardan tunnel and drive shaft about 2000
-Dana 44 complete rear end set around 2000
- Clutch package 1300
- Clutch pedal 100
- Master and slave cylinders about 200
Old Dec 23, 2022 | 04:39 AM
confused.but.driven
Cruising
may be a stupid question but where would be the best place to find parts like these?
Old Dec 23, 2022 | 03:21 PM
MrBigDee's Avatar
MrBigDee
There have been whole ZF swap packages for sale here on the forum and also Dana 44 rear end has been for sale
To manual conversion for an 87 c4
