From fuel supply line help!
I have a 1994 C4 manual and I want to replace my front fuel line.
The problem I have is my fuel filter is locktited on to the feed line to the rail and I know if I try and muscle it off I risk damaging the threads. So I figured I’d remove the line and the filter from the end that can be removed however I’m not sure where to buy a replacement for the line I’m taking out.
Any advice where to look or even links to sites would be greatly appreciated. The return line is braided and I’d like both lines to remain looking the same I’d also like to find new lines and wouldn’t be opposed to replacing both feed and return lines if it didn’t break the bank.
Thank you,
- C4 Newbie
Thank you,
- C4 Newbie
