Which end is up
Old Jan 5, 2023 | 01:59 PM
johnfin's Avatar
johnfin
Default Which end is up
Or inlet in this case. So I read that the C4 uses a reverse water pump. If thats the case which hose is the water inlet to the radiator? I assume its the top hose because thats where the thermostat is located.
Old Jan 5, 2023 | 02:12 PM
FostersPerformance's Avatar
FostersPerformance
The water pump pulley is reverse rotation, not the flow....they came up with that setup due to the serpentine belt having to turn the pump left hand In stead of right..other then that the hoses are like any other engine - out on top of engine to top of radiator. Bottom of radiator goes to water pump inlet.
