c4 corvette 84
Old Jan 7, 2023 | 04:42 PM
tb120021's Avatar
tb120021
2nd Gear
Default c4 corvette 84
does anyone have an idea my c4 corvette had to jump to start all the time so i went to get a brand new battery now nothing
everything works but no turn over no click nothing everything worked yesterday when jumped please someone give me an idea
Old Jan 7, 2023 | 06:03 PM
Topduarte's Avatar
Topduarte
Bad starter? Loose hot wire from starter?
Old Jan 7, 2023 | 06:20 PM
ex-x-fire's Avatar
ex-x-fire
Large starter wire should be 12 all the time, small starter wire 12v only when cranking. Starter is grounded through the engine block. Maybe a fusible link is blown.
Old Jan 7, 2023 | 06:31 PM
tb120021's Avatar
tb120021
2nd Gear
Default C4 not starting
If the fuse was blown all lights would still work ?
Old Jan 7, 2023 | 06:50 PM
JoBy's Avatar
JoBy
Old Jan 7, 2023 | 08:27 PM
Kilobuck84's Avatar
Kilobuck84
Will it start if you jump it now?
Since I can't see it from here I'm just going to throw out some things.
Check the voltage of the "new" battery and make sure it's actually charged.
Recheck the battery connections. Make sure they're clean and tight. Since this is the last thing you touched....
The anti-theft system will cause a no-crank. Try locking and unlocking the car with the key to see if you can disarm it.
Old Jan 8, 2023 | 09:24 AM
68blvert's Avatar
68blvert
Verify battery is actually good. Verify battery voltage at solenoid small post with key in crank position and battery voltage to solenoid large lug at all times. Voltage drop test cables. If all tests, good replace starter.
To c4 corvette 84
