Hall effect testing
Old Jan 12, 2023 | 07:12 PM
johnfin's Avatar
johnfin
Default Hall effect testing
I was going to test my HEI hall effect but i noticed it only has 2 wires, green and orange. Most have 3, plus, minus and signal. For some reason i cant find the hei wiring in the schematic. Any of you guys tested one? I assume they are using the hei body as the hall effect ground.
Old Jan 13, 2023 | 02:50 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
Unless you've got something other than an ordinary HEI/EST distributor, the pickup coil is a VR (variable reluctance). Two wires, AC signal.
Old Jan 13, 2023 | 05:02 PM
johnfin's Avatar
johnfin
Default Signal
I thought most hall effect sensors were + and - DC with the third wire being the square wave signal. I would like to test the sensor out of the car.
Old Jan 13, 2023 | 05:20 PM
69427's Avatar
69427
As I said earlier, they great majority of HEI/EST distributors have a VR sensor in them, not a Hall sensor. Can you post a picture of your particular distributor so that we're all on the same page?
Old Jan 13, 2023 | 06:44 PM
johnfin's Avatar
johnfin
Default Test
I put a vom on the unplugged coil and read .5 volt. So the 7 pin module must be an amp. Its even heat sinked. Whats interesting is i tested a few hei's i have and they all tested different, mostly lower voltages like .05.
Old Jan 13, 2023 | 09:56 PM
69427's Avatar
69427
The pickup coil only generates a voltage when the distributor/reluctor wheel is turning. That's how a VR sensor works. The 7TM processes the AC signal from the VR sensor and outputs a square wave signal to the ECM for timing and RPM calculations. The 7TM internal power transistor switches the coil primary current on and off, using the EST timing signal from the ECM during normal run mode, and its internal timing signal during cranking and ECM-failure modes.
To Hall effect testing
