Fuel injector clips
Old Jan 13, 2023 | 02:45 PM
jseremba's Avatar
jseremba
Default Fuel injector clips
Hello, When you repair/replace fuel injectors do you put the clips back in? Thank you
Old Jan 13, 2023 | 04:40 PM
sflier's Avatar
sflier
I reused / reinstalled the clips but some people don't. It doesn't seem to make a difference. If you ever want to pull the fuel rail up with the injectors attached to test for fuel leakdown or flow from the injectors, you'll need to have the clips in place.
Old Jan 13, 2023 | 04:57 PM
jseremba's Avatar
jseremba
Thank you for the response. I had so much trouble removing them. I removed them from my 89 years ago. I don't remember having an trouble. Well thank you.
Old Jan 14, 2023 | 02:08 AM
topfuel67's Avatar
topfuel67
I upgraded the injectors on my 92. I read that you don't reuse the clips. That was wrong. The injectors need the clips to stay in place. The new Bosch III injectors took the same clip as the old style injectors.
Old Jan 14, 2023 | 05:30 AM
jseremba's Avatar
jseremba
Does not using the clip cause a noticeable problem. Do they fall out. Thank you
Old Jan 14, 2023 | 11:25 AM
topfuel67's Avatar
topfuel67
The 40+ psi pushed the injectors too deep into the intake manifold and fuel sprayed out the top. They seem to sit right until you start it up.
Old Jan 14, 2023 | 11:32 AM
jseremba's Avatar
jseremba
Thank you
To Fuel injector clips
