Cuts out while driving
Old Jan 14, 2023 | 02:23 PM
Kento87's Avatar
Kento87
Cruising
Default Cuts out while driving
I'm looking at a 92 and it has an odd hickup. Driving along it just shuts down for 1 or 2 seconds, empty wallet light pops on then it restarts and the light goes out. It is a manual car. Current owner says the codes stored are random not the same everytime. The car only had 60k and is in great shape. Only thing is the tires are 06 date code so those have to be replaced ASAP. Thanks in advance.
Old Jan 14, 2023 | 02:39 PM
CorvetteRules's Avatar
CorvetteRules
Get the owner to give you the codes or better yet pull them yourself. there may be "random" codes but that doesn't mean they wound give a starting point to track down the stalling issue.
Old Jan 14, 2023 | 02:49 PM
Kento87's Avatar
Kento87
Cruising
I'm worried it is an Optispark issue
Old Jan 14, 2023 | 04:48 PM
CorvetteRules
Again, pull the codes and come back with what they are and people here can help you. if you don't have access to a code reader read this - C4 Diagnostic Trouble Codes - Corvette Central Tech Blog
Old Jan 14, 2023 | 04:56 PM
Kento87's Avatar
Kento87
Cruising
I have owned Fieros for years, I know about the jumper to get codes. I'm just trying get an idea what it could be before I make an offer. It is going to be different if it is a coil/icm vs Optispark. I already have to get new tires cause they have an 06 date code on them
Old Jan 15, 2023 | 04:21 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
I'm thinking one of 3 things:
  1. Bad ground (meaning it needs cleaning). On my 89, it was the terminal behind the battery
  2. Bad ECM (meaning a solder joint is loose leading to new ECM) Had to buy a new ECM in 2001 for my 89
  3. Optispark (or related ignition connection) Happened on another car AND have read this for LTx owners.
I've had all 3 cause similar issue over the years.
Old Jan 15, 2023 | 04:47 AM
Kento87's Avatar
Kento87
Cruising
Thank you all for your input but the seller is not dropping his price so I passed on it.
Old Jan 15, 2023 | 01:41 PM
Vets-Vet's Avatar
Vets-Vet
What was the price now that you have passed ??
Old Jan 15, 2023 | 01:44 PM
Kento87's Avatar
Kento87
Cruising
10,500. Needed new tires right away plus tracking down the miss so I offered 9500.
To Cuts out while driving
