Any LT1 NOS set ups info ???
Old Jan 18, 2023 | 11:47 PM
ME93's Avatar
ME93
Default Any LT1 NOS set ups info ???
got a few new mustangs wanna race me so i wanna put some juice on it to play with them. thanks guys.
Old Jan 19, 2023 | 02:53 PM
dizwiz24's Avatar
dizwiz24
ive got mine wired into the horn button
i throw a switch and the horn stops functioning as a horn and instead sprays nitrous / fuel provided.
1. Its at wot
2. rpm window of 3000 to 6200
3. The system master switch is armed /bottle valve opened (duh)
i also have a relay that throws my stock computer into a mode that reduces wot timing 2 degrees while rhe nitrous is spraying
its a 75 wet nx system on a 1993 corvette 6spd lt1 with a procharger d1-sc pushing 15 psi boost
fuel system is obviously built up and i am using stock ecm still. Works fine with boost (did convert to 2 bar MAP)
engine is still stock bottom end. Holds together fine. But i run e85 and did reduce compreasion to 9.7:1 thru bigger cc afr 195 elim comp port heads
Old Jan 19, 2023 | 03:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Beat 'em with driving.
Old Jan 19, 2023 | 03:41 PM
Krusty84's Avatar
Krusty84
Use a quality parts when selecting your window switch, fuel pressure cutoff switch and wot switch.
If they are Gen 3 Coyotes with 10 speeds, you are going to need a big shot.
Good luck.
Old Jan 19, 2023 | 04:04 PM
dizwiz24's Avatar
dizwiz24
those 10 speeds have so many gears they are always shifting all day long
and if they’ve boosted them , that makes them even worse bc they are always blowing off boost with every shift
i agree with Tom - beat them with your driving and dont let them hit you.
they usually crash (i see the youtube and instagram videos) in any kind of performance situation
Old Jan 19, 2023 | 05:13 PM
Krusty84's Avatar
Krusty84
The A10 is killer. 8-12 millisecond shifts. They spend less time shifting down the entire 1/4 mile than any true manual does in 1 shift.
And when boosted, they don't bleed any significant amount of boost. I have ridden in several out at the meets. The boost will stay pegged.
https://m.youtube.com/shorts/-gn-nJbe2DU
Edit: My apologies to the OP. Not trying to hijack the thread.
Old Jan 19, 2023 | 07:51 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That thing sounded like it "wasn't shifting"....or it was shifting way too late. Evidenced by the speedo rate almost stopping at the top of each gear.
Old Jan 28, 2023 | 01:40 AM
ME93's Avatar
ME93
1. Its at wot
what time and mph you run in the qtr ? gears tires ? thanks.
Old Jan 29, 2023 | 10:06 AM
dizwiz24's Avatar
dizwiz24
11.1@ 132, 1.9 60 ft
should be mid 10s , with a better driver shifting thru the 6spd
toyo r888r’s p315/35r17, stock 3.45:1 D44 gearing
surprisingly i get hook on the prepp’d track surface even spraying nitrous in 1st gear off the line
Old Feb 14, 2023 | 04:23 AM
ME93's Avatar
ME93
so only one other person in this forum has put nos on a lt1 ???? amazing huh lol
Old Feb 15, 2023 | 10:48 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It was probably more popular mod in 1992/'93.
To Any LT1 NOS set ups info ???
