Heads
Old Jan 20, 2023 | 10:24 PM
jseremba's Avatar
jseremba
Default Heads
I received my heads from the machine shop. The rocker arm studs are not in the heads. What torque do I use for the studs and guide plates.
Thank you
Old Jan 20, 2023 | 11:49 PM
78blueta's Avatar
78blueta
50 ft lbs with threads lubricated with engine oil
Old Jan 21, 2023 | 08:44 AM
jseremba's Avatar
jseremba
Thank you. Do you use locktite
Old Jan 21, 2023 | 10:18 AM
htrdbmr's Avatar
htrdbmr
Thank you
If the intake stud holes go through into the port, use a thread sealant 50 lb/ft sounds right.
Old Jan 21, 2023 | 10:21 AM
jseremba's Avatar
jseremba
Thank you. The service manual says 50. It just seems high.
THe machine shop disassembled the heads. There are short 10 mm bolts. I think I know where they go. Do they hold anything on place
To Heads
