Clutch hydraulics
Old Jan 21, 2023 | 04:42 PM
johnfin's Avatar
johnfin
Default Clutch hydraulics
New system installed and i cant get the air out of the system. Have gone thru a whole quart of fluid. Tried juat about everything except power bleeding which i dont want to spend another $100 on a bleeder. I have tried a hand vacuum pump and the old school method via the pedal and foot. Pedal is still mush. Any tips
Old Jan 21, 2023 | 05:29 PM
LiveWire1's Avatar
LiveWire1
The old school method worked great for me. Pump the pedal 10 times or enough to pump it up. Hold it down for 30 seconds, then slide your foot off the side, letting the pedal pop up. Repeat a few times, and that should result in a pedal that works for you. Periodically do it while you're driving and you should be good!
Old Jan 21, 2023 | 05:39 PM
johnfin's Avatar
johnfin
Default Slave
How does that get air trapped in the lower slave unit?
Old Jan 21, 2023 | 05:40 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Pumping the pedal works.
Old Jan 21, 2023 | 06:22 PM
johnfin's Avatar
johnfin
Default Pedal
How hard should the pedal be when perfect? Ie like the brake pedal?
Old Jan 21, 2023 | 06:46 PM
s carter's Avatar
s carter
the clutch will never feel like the brake if it does you need brake work.
Now can you get the into gear without grinding, is the friction point in the middle of the travel on the way up. You should feel some resistance from the top.
Also since the day is winding down do nothing leave the cap loose and let it set overnight top off and test it in the morning.
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
It's not a matter of pedal "hardness"....it's more the free play and point of engagement. There should be essentially no free play. Engagement should begin ABOUT 1/2 to 2/3 of the way up from the floor.
Old Jan 22, 2023 | 01:24 PM
MrBigDee's Avatar
MrBigDee
I bled my clutch a few months ago.
I turned the slave cylinder upside down and then carefully pressed against the clutch housing, so that any air can escape.
But you have to check often that the tank doesn't get empty.
I did it a few times and the clutch works normally
Old Jan 22, 2023 | 04:05 PM
Hawkeye56's Avatar
Hawkeye56
ZF Doc recommendations to push clutch down about half way repeatedly to bleed the system .
By doing this you will be recirculating the fluid from the slave cylinder to the master cylinder.
This is how I bleed mine after a all new clutch and ect.
Thanks Hawkeye56
Old Jan 22, 2023 | 07:45 PM
MatthewMiller's Avatar
MatthewMiller
I agree with the others: try the repeated partial push and also the one where you push the pedal all the way down and slip your foot off the side of the pedal to let it pop up. Each one at least 50 times. It seems ridiculous after you've already done the standard bleeding methods, but it gets the job done where the standard method doesn't. I had to do it on mine, too.
Old Jan 22, 2023 | 08:03 PM
pedricd's Avatar
pedricd
Pumping works and works fine. I’ve only heard of a few things where this does not:
- install of the master cylinder without the firewall spacer
- slave entirely full of air (I still think pedal ranger method should handle this)
- defective parts (unlikely)
Stop trying to bleed the slave! Do not open the bleeder as you are likely introducing more air than removing.
Also, it sounds like you are unsure about how the pedal should feel? You should have close to the same “firmness” of pedal all the way to the floor. It is not like a brake pedal that gets harder to press and “stops” due to pressure before you reach the floor. The pedal should go through full travel to its limit as you are mechanically “pulling apart” a spring loaded pressure plate.
Old Jan 22, 2023 | 08:56 PM
johnfin's Avatar
johnfin
When the pedal is working, what would the typical fork movement be. I can feel it move about 1/8"-1/4" through the boot
To Clutch hydraulics
