1988 L98 Stock Pushrod Length?
Old Feb 1, 2023 | 11:41 AM
1988C4Owner's Avatar
1988C4Owner
Default 1988 L98 Stock Pushrod Length?
Hello all, I purchased this top end kit a while back and the pushrods seem to be really long. I made the mistake of throwing out my old set before checking that they were the same. How long are the pushrods supposed to be? The 1988 L98 has a hydraulic roller cam and aluminum heads, and I was only able to find info on a flat tappet cam with cast iron heads. Any help is appreciated!
Old Feb 1, 2023 | 01:00 PM
WVZR-1's Avatar
WVZR-1
Original push rods would have been GM# 10046173. You should be able to find several locations that would ID the length and diameter of that part #.
Old Feb 2, 2023 | 10:27 AM
jazfe's Avatar
jazfe
I saved my stock pushrods. Currently at work but when I get home I will measure them and report back.
Old Feb 2, 2023 | 04:49 PM
TorchLT4's Avatar
TorchLT4
Just shy of 7.2 like 7.195
Old Feb 3, 2023 | 03:09 PM
jazfe's Avatar
jazfe
My stock ones are 7 3/16. or if you like 7.1875.
I have a complete set that came out of my 86 which is a roller engine with the aluminum heads. I also have a set of 7.250 that are hardened just sitting around.
If you want them PM me.
Old Feb 7, 2023 | 01:31 AM
iceman2003's Avatar
iceman2003
Hello, as far as I know 1986 Corvettes are not roller engines. that feature was a 1987 onward one. I would assume the push rods are different lengths.
Thanks, ...
Old Feb 7, 2023 | 01:39 AM
jazfe's Avatar
jazfe
Thanks, ...
Not Correct...................Late 86 came with the roller cam and aluminum heads. I know, I own one.
To 1988 L98 Stock Pushrod Length?
