Electrical Problems?? Help!
Old Jan 12, 2003 | 10:25 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Default Electrical Problems?? Help!
Richland WA
Electrical Problems(86)...HELP! 12:21 AM 1/13/2003
Alright, I just recently acquired this 86 Vette coupe.
I tried the cruise control by moving the switch to the on position and it didn't work. Shortly after the dirctional signal lights quit working. When I stopped the car I noticed a smell like burning electrical wires. I opened the hood and noticed that the horns had been disconnected by the previous owner. I checked the fuses for the turn signals and the cruise control and they had not blown. My other electrical items and lights are still working.
I am guessing that I have a short in the wiring in the steering column but I don't understand why the fuses didn't blow?
Any ideas if this is the likely cause and if so how I replace the wiring in the steering column? The burning smell was noticable under the hood, by the brake booster area it was the most apparent. It wasn't really present in the interior of the car. Any ideas as to other items that might have gone out and how to diagnose and repair?
Thanks in advance,
Chris
Old Jan 13, 2003 | 12:21 PM
jfb's Avatar
jfb
Default Re: Electrical Problems?? Help! (USAsOnlyWay)
Buy the electrical service manual for your 86 from GM. This is an excellent manual with pictures of where parts are mounted and a good diagnostic page on each part of the electrical system including schematics. You must have a schematic and a description of the system if you don't want to spend the rest of your life debugging your electrical system. You can get further help here, but you can't beat that manual.
Old Jan 14, 2003 | 12:23 AM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Default Re: Electrical Problems?? Help! (jfb)
Ditto on the manual....I have an '84 and the genuine chevy corvette manual has helped me to the max......don't scrimp......buy it......you'll be much happier if you do...and it will answer so many questions....
tony
Just my thoughts....
:iagree: :steering:
Old Jan 14, 2003 | 12:46 AM
DF's Avatar
DF
Ah....the C4....the only vehicle with more miles of wire than a 747.
Have fun replacing the wiring in the steering column. When I had it apart it looked like you would have to totally dissasemble it to get it out of there! :crazy: Get the service manual before attempting this!
Good luck! :cheers:
Old Jan 14, 2003 | 12:49 AM
Mike's 86's Avatar
Mike's 86
:iagree: On getting a manual, very helpful. I have one my self. Too much to scan all diagrams but if you need a specific area I might be able to help.
good luck :cheers:
Old Jan 14, 2003 | 03:09 AM
USAsOnlyWay
Default Re: Electrical Problems?? Help! (Mike_D)
Alright sounds like I should get the manual.. . ;)
So now, this whole operation, which sounds like I will be ripping apart the column, replacing the wiring harness for the signals and anything else I find... plus the relays which I am pretty sure are toasted from the smell... how long would you guys estimate I should put aside for this?
P.S. Yes the manual is on the way.
Old Jan 14, 2003 | 05:17 AM
hngacurv's Avatar
hngacurv
I will save you some time. I tried to buy one for an 86 from Helm and FactoryAutoManuals and both of them told me they were out.
Old Jan 14, 2003 | 03:09 PM
USAsOnlyWay
Do I need to buy a seperate manual for wiring, or is that included in the original shop manual???
Old Jan 14, 2003 | 03:15 PM
allenw@icsgroup.com's Avatar
allenw@icsgroup.com
8th Gear
dido the last question. Is there a seperate wiring/electric manual
for the 85-C4 than the shop manual?
We better get some befor they go out of print or avaiablity.
allen
Old Jan 14, 2003 | 09:28 PM
KYVette90's Avatar
KYVette90
Default Re: Electrical Problems?? Help! (allenw@icsgroup.com)
The horns were probably bad. Push the horn buttons and listen for the horn relay to click. If it does, that means the actual horns are more than likely bad. On the cruise control, take the connector off of the cc servo and clean the contacts real good and plug it back in, it fixed mine. On the turn signals, check the bulbs, if they are good the switch is bad or you have another electrical problem like you already said. If all of your fuses are good and in place you probably don't have a short because the fuses would probably be blown. On the burnt electrical smell under the hood, check to see if a wire is touching the exhaust, like an 02 sensor wire. :cheers:
[Modified by KYVette90, 8:29 PM 1/14/2003]
To Electrical Problems?? Help!
