Rear Window Defroster
Old Jan 12, 2003 | 11:14 PM
jimswhite92's Avatar
jimswhite92
Default Rear Window Defroster
Just purchased a 1992 LT1 coupe. Didn't get an owner's manual. I'll try to locate on online. My back window appears to have some type defroster (lines in the glass???)
If so, how do I turn on the defroster. There is a switch on the panel for a mirror defroster. Can't seem to find a switch for a rear window defroster (if there is one.:confused:)
Thanks in advance for any feedback.
Old Jan 12, 2003 | 11:48 PM
92TripleBlack's Avatar
92TripleBlack
Default Re: Rear Window Defroster (jimswhite92)
The mirrors and rear operate off the same switch. In '92 they didn't offer a rear window defroster on the vert. Rather than make two different consoles, one with and one without rear window buttons, they combined then and just marked it mirror so it would be interchangable. :yesnod:
Old Jan 13, 2003 | 12:18 AM
jimswhite92
Default Re: Rear Window Defroster (92TripleBlack)
Thanks for the feedback... Are you telling me there is no rear defroster on the rear glass on the 92???
Old Jan 13, 2003 | 12:23 AM
Wheelman's Avatar
Wheelman
no defroster on 92 convertibles.
Old Jan 13, 2003 | 12:36 AM
92TripleBlack
Default Re: Rear Window Defroster (Wheelman)
No glass or defroster on verts until '94. Prior to that it was a flexible plastic window. Took care of that last summer. :D
Old Jan 13, 2003 | 06:11 AM
jimswhite92
Sorry with my description. I have a coupe with a glass back window. Does it defrost... Real novice here :confused: :confused:
Old Jan 13, 2003 | 09:28 AM
Steel Blue 91's Avatar
Steel Blue 91
Yes, it should defog with the mirrors. As said above, there is no separate switch just for the defogger.
Old Jan 13, 2003 | 02:04 PM
JasonL's Avatar
JasonL
Inspect the wires that attach to the ends of the hatch struts. They often get brittle, overheat and break, bingo...no more defroster. Hope that helps.
Old Jan 13, 2003 | 03:14 PM
jimswhite92
Default Re: Rear Window Defroster (JasonL)
Appreciate the help. I'll try next time we have a frost. I am anxious to see if it works. :) :) :)
To Rear Window Defroster
