I have a 1994 Corvette lt1. Just put motor back in and fired up just fine. Only issue is the Fuel pump continuously runs with key off and out of ignition. I pulled relay from under dash bolster. No luck
Found a post from 2016. Unplugged oil pressure sending unit and pump turned off. Going to install new sending unit.
Reason: Fixed issue
Most times the 'MOD' who moved it will mention the move! That didn't happen this time around though. Poster #2 could maybe have mentioned a bit more in his post!!
OP - What have you checked so far? Do you have the FSM (Factory/Field Service Manual)?
