HEI plug/connector
Old Feb 15, 2023 | 01:54 PM
johnfin's Avatar
johnfin
Default HEI plug/connector
What does this connector look like that goes to the dist. cover and is it part of the harness that comes thru the drivers side of the car. not the RH firewall. Says LH in the picture.
Old Feb 15, 2023 | 03:38 PM
Tunedport90's Avatar
Tunedport90
Like this colors should be pink or red and white or brown for tach filter
Old Feb 15, 2023 | 05:36 PM
johnfin's Avatar
johnfin
Where does the 3rd ground wire go and where can i get those connectors?
Old Feb 15, 2023 | 05:40 PM
Tunedport90
Are you asking about the bellhousing bolt ground or hei ground strap under the cap ?
you can get Hei power and tach connectors on eBay or Amazon.
Old Feb 15, 2023 | 09:02 PM
johnfin's Avatar
johnfin
The center ground connector under the cap cover.
Old Feb 15, 2023 | 09:03 PM
Tunedport90
https://www.ebay.com/itm/35450412033...mis&media=COPY
Old Feb 15, 2023 | 09:16 PM
Tunedport90
Amazon Amazon
might check icm PIN numbers but I think this is correct
Old Feb 16, 2023 | 07:28 AM
johnfin's Avatar
johnfin
I have that part I just thought there was a 3 way plug that captured all of the connectors at once
Old Feb 16, 2023 | 09:49 AM
Tunedport90
Not that I’ve ever seen on a hei
Old Feb 20, 2023 | 07:27 PM
64Scout's Avatar
64Scout
I've seen them, on older HEI distributors. The single plug with three wires goes down inside the distributor to the ignition module, then there was another wire for power and one for tach if you needed it. I haven't looked at mine to know if it has that three wire plug or not.
Old Feb 20, 2023 | 07:46 PM
Tunedport90
Icm has 4 wires is that what your referring to ?
Old Feb 20, 2023 | 09:23 PM
WVZR-1's Avatar
WVZR-1
2 wires into a single connector yes but no 3 wires into a single.
Old Feb 21, 2023 | 07:30 AM
johnfin's Avatar
johnfin
So far I have found only one wire in my left harness that is pink with a single white connector. I believe that is the power to the hei. Is that all I need on that side to get the car to start. Also, is that pic you posted from a C4 corvette
Old Feb 21, 2023 | 09:51 AM
WVZR-1's Avatar
WVZR-1
Pink would come from C100 drivers-side firewall. I would doubt that's a C4 distributor. All HEI were typical. If everything else is connected correctly and operational, adding IGN (PNK) to correct terminal of HEI should enable run.
Old Feb 21, 2023 | 03:52 PM
Vets-Vet's Avatar
Vets-Vet
The 3 wire comes from the base of the distributor (capacitor terminal block). The white and brown connectors in my hands (pic2) are backwords, white should be on right.
Old Feb 21, 2023 | 03:55 PM
Vette5311's Avatar
Vette5311
You may need to increase power feed to HEI gauge, not just tap into the pink one. Lots of information out there on it.
Old Feb 21, 2023 | 04:10 PM
Vets-Vet's Avatar
Vets-Vet
To HEI plug/connector
Old Feb 21, 2023 | 04:44 PM
Vets-Vet's Avatar
Vets-Vet
The pink single wire connector comes from large harness bundle behind and below distributor.
Old Feb 21, 2023 | 05:46 PM
johnfin's Avatar
johnfin
Thanks vets vet for the great pics and sorry for the dumb questions. Am scratch building this car so actual pics help get it together. My 3 wires that come out of the hei to that connector are red black and yellow so i guess yellow is brown. But at least i now know that connector goes to the coil. I was wondering about that. So what color wire is the tach wire. I have a stray light wire without a connector that looks like it could be it.
Old Feb 22, 2023 | 01:03 PM
johnfin's Avatar
johnfin
There is something on the schematic that says tach filter. Where is that located?
