86 c4 l98 inconsistent revving
Old Feb 16, 2023 | 03:54 PM
C486@16's Avatar
C486@16
4th Gear
Default 86 c4 l98 inconsistent revving
I've got an 86 with the l98. It has been off the road since at least 08 and I've been trying to get it running. It cranks up fine and idles decent but doesn't rev well at all. If I slowly give it gas it will rev as much as i want to but if I do it at any more speed it won't rev.
I Checked compression and they are all around 120 psi.
I've tried removing air filter and didn't do anything.
I've took the plenum and pipes off plenty of times.
I'm stumped at this point
I've checked timing, fuel pressure, changed injectors, changed coil, changed the module under the distributor cap, changed maf sensor, tps, iac valve, intake air sensor, vacuum lines, changed fuel pump, fuel filter, blew lines out to tank, changed maf burn off and power relays, o2 sensor, and I can't get it running right at all.
Edit: I just remembered that I had to use silicone to seal the distributor cap as well because the original parts were dry rotted but it was running about the same before and after that
Old Feb 16, 2023 | 06:20 PM
s carter's Avatar
s carter
Find a scan tool and check o2 sensor if its not reading right it will make the car surge a bit and it falls under the world of they should be changed every few years or at least looked at
Old Feb 17, 2023 | 08:21 AM
C486@16's Avatar
C486@16
4th Gear
I'm sorry I forgot to say but I have changed the o2 sensor recently so it's new
Old Feb 18, 2023 | 01:29 AM
iceman2003's Avatar
iceman2003
I guess your car must be in limp mode, or a clogged catalytic converter, but if its not electrical it must be a fuel issue. Maybe fuel pump filter sock could be collapsing or lastly the fuel regulator may be malfunctioning. Good luck, let us know what it turns out to be, thanks, Cheers, Jarrod
Old Feb 18, 2023 | 11:19 AM
jazfe's Avatar
jazfe
I have had that issue in the past.
I advanced the timing from 6 to 12 BTDC and that fixed my issue. I suspect my timing mark has slipped on the balancer.
Give it a go
When you set your timing was the ESC wire disconnected?
Old Feb 18, 2023 | 12:36 PM
C486@16's Avatar
C486@16
4th Gear
Give it a go
My esc wire was disconnected and I'll give it a go. Thank you
To 86 c4 l98 inconsistent revving
