96 LT4 Clutch Recommendations
Old Feb 18, 2023 | 09:01 AM
1993C4LT1's Avatar
1993C4LT1
Default 96 LT4 Clutch Recommendations
Hi everyone. This will be my first clutch swap, but I have my dad's help who has done it several times on C5's. Trans is out of my car.
I was happy with the stock clutch pedal feel. In my opinion, it wasn't overly light or heavy. It'll be a street car 90% of time.
The most I ever plan to do to my LT4 power wise:
lt4 hotcam
Ported heads and intake
Longtubes, free flowing exhaust
AO Forced Air
And tune, of course.
Not concerned with saving money, just want the best option.
Old Feb 18, 2023 | 09:41 AM
grandspt's Avatar
grandspt
If your dual mass flywheel is in good condition then go with a stock replacement disk ( if your pressure plate is stock and in good condition use that too).
All the replacement pressure plates and throw out bearings for the C4 6speed cars are all made in China and are not as good as the originals. It doesn't seem to matter what brand or name is on them they all come from the same Chinese plant with questionable reliability unfortunately.
If your dual mass flywheel is bad then go to the RAM C4 conversion kit. It is all made in the USA . The kit converts the stock pull style pressure plate to a normal pull style. It comes as a kit with everything except for the flywheel bolts and input shaft alignment tool.
I also recommend a shim for the transmission since the transmission is going to make noise without the dual mass flywheel now.
The shim can be purchased from Bill Boudreau ZF doc.
I went the stock type setup and I had slippage from all the Chinese junk. I ended up buying the RAM the second time around and am pretty happy with it.
Good luck!
Old Feb 18, 2023 | 09:47 AM
1993C4LT1's Avatar
1993C4LT1
I was thinking RAM also. Anyone have a link that describes their options? Such as the single disc, twin disc, organic clutch etc. And yes, I will buy a few thing of ZF Doc.
Old Feb 18, 2023 | 10:49 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
I would stick with stock; it's stronger than strong enough for your future plans. A twin disk is massive overkill and is a great way to break parts.
Old Feb 18, 2023 | 11:09 AM
pedricd's Avatar
pedricd
+1 on the RAM setup IF the DMF is toast OR you want to lighten the flywheel. I went with the steel +organic disk. Supposed to be rated 450+ hp…and that’s the lowest strength one. If you really want to go to the RAM setup, either email or call them…they can help you.
If you are stock or not pushing well over 400 I’d just go with organic for the streetability.
You can also just google/pull up their portions for the c4 on their site.
Again if your DMF is fine I’d consider getting a trued up PP from zfdoc…that did NOT work well for @grandspt but might for you.
To me the two best options are DMF with stock style setup or RAM if you are going SMF. Just do the cost comparisons for SMF conversion…depending on your selections it wasn’t that far apart for me.
Old Feb 18, 2023 | 01:30 PM
russlg6584's Avatar
russlg6584
Good luck!
I second everything grandspt says.
here is video of the Ram install on a supercharged C4… a lot of useful info in that vid. I’ve spent HOURS researching clutch options on this site and what grandspt says is in a nutshell what the consensus of opinion that I found. My trans is currently out of my 1993 and Bill @ZFdoc recommended I reuse my DMF based on photo’s I sent him. Getting a New LUK China Clutch kit from Carolina Clutch but if my DMF were toast RAM would be the way I would go. When Bill emailed me about my clutch situation he told me he was currently out of the shim for the shim kit and didn’t know when he would be able to make more. Carolina lists it as a product on the C4 page on their website you just have to really look for it. I haven’t called to see if they have stock in house or not…
Old Feb 19, 2023 | 07:33 PM
MatthewMiller's Avatar
MatthewMiller
Whether your flywheel needs to be replaced or not, I would not recommend the expense and extra work of the RAM conversion if your original pressure plate is still good. If you need a new flywheel, just get a steel single-mass one and consider the countershaft shim kit already mentioned. Then just get a good organic disk (but if you ditch the stock dual-mass flywheel then be sure to get a sprung-hub disk) and you're golden. If you still have the stock INA throwout bearing, I'd even consider reusing that. The problems come when you have to get a new pressure plate and throwout bearing: all the new replacements now are made in China and they are not good. If you have to replace both of those, then that is when I would start thinking about the RAM conversion.
Old Feb 19, 2023 | 09:40 PM
Gale Banks 80''s Avatar
Gale Banks 80'
https://youtube.com/watch?v=ZUZiS_qg...SIkaIECMiOmarE
I watched this Video a couple of times before installing mine. I would probably use it as how to Not to install it ! As per all U-Tube videos they Skip the hard parts. And boy did they sure make it hard on them selves ! They bored a hole in the Bellhousing to run the Hyd Lines threw and not to align the Slave Cylinder. Since they bored the hole in wrong spot its no wonder they skipped this part of the Video. If I was to do it all over I would ask Ram to make the Hyd Lines twice as long so that they would reach all the way to the Master Cylinder. For those who have installed the Ram watch this Video for a good Chuckle.
Old Feb 19, 2023 | 09:55 PM
grandspt's Avatar
grandspt
To the OP, if you need to replace the flywheel, throw out bearing, clutch disc, pressure plate and the hydraulics then the RAM is very similarly priced.
Contact RAM, Mike Norcia was very helpful answering all of my questions.
Also the RAM conversion kit requires a few measurements to select the proper shim for the hydraulic throw out bearing. Not hard to do at all!
RAM also recommends drilling a hole in the bell housing. I did not. I found that the opening where the stock clutch fork use to reside was enough for me to align and inspect the hydraulic throw out bearing. The RAM included hydraulic lines exit through the stock clutch fork opening too. I used an inspection camera to make sure the bearing was on the transmission input shaft.
But if all you need is a clutch disk just replace that and reuse your stock DMF, pressure plate, and throw out bearing.
Old Feb 24, 2023 | 11:55 PM
1993C4LT1's Avatar
1993C4LT1
@grandspt @pedricd How is the RAM setup bled compared to stock? Easier, or harder?
Old Feb 25, 2023 | 09:08 AM
pedricd's Avatar
pedricd
I would say similar, but slightly easier. There is a remote hose which makes the bleeder more accessible, and the external slave is gone so plenty of room. I bled mine with my son pumping the clutch…that is the best way and it worked fine, first try. I also had no trouble whatsoever bleeding the stock setup, even after a complete hydraulic change.
Having said that I did not like the bleeder itself. Perhaps I used the wrong fitting but I could see no other way with the fittings I had and ended up with the bleeder screwed directly into the braided line. This makes vacuum bleeding from below almost impossible (as soon as you loosen air can leak in from around the nut). I would just ask RAM about it (as I should have). @grndsprt probably didn’t run into that. But again I had no issue bleeding it using the old school method.
Add to that if you get most of the air out the master should self bleed anyway with just lots of pumping and it will be fine (either with the stock setup or RAM.
Honestly, and thinking about it more, you should not make this a factor either way, IMO.
Old Feb 25, 2023 | 08:59 PM
grandspt's Avatar
grandspt
I bled both the stock hydraulic slave and the new RAM hydraulic throw out bearing with a Mighty Vac hand pump. So I never really had an issue bleeding either one. As long as you wrap Teflon tape around the threads bleeding should not be a problem.
The RAM like pedricd has stated has the bleeder nut screwed into one end of the included braided line. So you need two wrenches (forgot the size, but boxed end makes it easier) to unscrew the bleeder from the hydraulic braided line.
Old Feb 26, 2023 | 01:11 AM
Gale Banks 80'
I would consider the Ram much better. The Ram Slave Cylinder is a Two Hose set up where most all Stock Masters are a One Hose. The only thing I didn't like about the Ram is there Hoses are to short to take full advantage of a Two Hose system. They need to be long enough to reach all the way to the Master and the Bleeder needs to reach up to the Firewall. I'm sure a phone call when ordering it could remedy this just tell them you want them twice as long. This way there is no need to get under the car. After a couple of years is the Fluid getting dark and you want to change it ? No problem just open the Bleeder Hose and pump away till You like to color again. Try doing that on a C5 or newer Corvette.
Old Feb 26, 2023 | 10:09 PM
1993C4LT1's Avatar
1993C4LT1
Perfect insight I was looking for, thanks guys!!
Old Feb 27, 2023 | 07:55 PM
russlg6584's Avatar
russlg6584
I’ve looked for just the disc for the clutch set up and all I’ve found are clutch kits, all a different variation of the LUK/Valeo OE replacement kit. Only individual discs I’ve found are one for a ZR1 on eBay and center force discs to be used with the stock set up but for cars with mods to handle higher hp. Mine is stock and will remain for the most part stock. My dilemma is between using the original pp and TOB. My bell housing was chock full of mouse nest material and wedged its way into all crevices of my pp when the clutch was disengaged. Who knows how long that went on before I owned the car. I used a press to disengage the pressure plate and got a lot of the crap out using different style picks and compressed air but some still remains. I ordered a LUK rep set kit. I’m going to compare the pressure plates to see which one looks better. I plan to def reuse my old TOB as the one in the LUK kit will be the junk Chinese one.
Old Feb 28, 2023 | 11:02 AM
yakmastermax's Avatar
yakmastermax
Bump for interest. I am looking at an LT4 car but it has noise from the transmission/bellhousing, a sort of whine, but "No noise except when idling in neutral and clutch released"
Old Feb 28, 2023 | 12:04 PM
pedricd's Avatar
pedricd
that’s very likely the pilot bearing being worn or a misalignment of trans to engine or both. If it’s not too severe it can be ok for a while, but if bad enough would need to be replaced. I have a thread on my clutch job where I linked to a YouTube vid of my whine sound you can hear to verify if it is a similar thing. Also Zfdoc description of cause etc in there.
To 96 LT4 Clutch Recommendations
Old Feb 28, 2023 | 12:51 PM
MatthewMiller
I could be wrong, but I think the throwout bearing probably wouldn't make noise unless the clutch pedal is depressed. Otherwise, there is little or no pressure on it and it should be pretty quiet. I think the misalignment thing is a very likely culprit, though.
Old Feb 28, 2023 | 01:00 PM
pedricd's Avatar
pedricd
TO bearing makes noise generally with clutch pedal depressed when it’s doing work. Foot off pedal and in neutral very likely pilot bearing worn and losing centering support of the input shaft. This transmits a whirring vibration through the clutch disk via the splines/slight wobble…. It’s usually not a big deal up to a point…. Again this would be mostly a “whirring” sound but hard to judge without hearing it.
mine was toasted due to it being greased (pilot bushing self lubricates) and likely accelerated by not getting the bellhousing to engine surface true (so slight misalignment). Even given that zfdoc seemed to think it was ok based on him hearing the YouTube audio unless it got noticeably worse…
Old Feb 28, 2023 | 02:11 PM
MatthewMiller
Well, I had a brain disappearance and conflated pilot bushing and throwout bearing when I read your previous post. Sorry. But yeah, we agree.
