bad ball joints
Old Jan 13, 2003 | 03:12 PM
workng247's Avatar
workng247
6th Gear
Default bad ball joints
I'm rebuilding the front end on my 85 and I'm having a hard time finding the right size replacement lower ball joints. I've gotten them from 3 differrent sources so far and keep getting exactly the same part with different brand names. The problem is that they measure .015 inches larger in diameter than the old ones I removed. It doesn't sound like much but its obvious that they won't fit into the A-arm without doing some damage. Has anybody else run into this or have any ideas? I guess I'll keep ordering them from different places and hope I get something that will work. Thanks.
Old Jan 13, 2003 | 04:50 PM
scorpion's Avatar
scorpion
Default Re: bad ball joints (workng247)
welcome to the club!
i had the same problem on my 95
i kept getting ball joints for the c3, which are slightly larger.
i endened up buying all ball joints and tie rod ends from the dealer. kinda costly, but i got a pretty decent discount.
good luck!
Old Jan 13, 2003 | 08:20 PM
workng247's Avatar
workng247
6th Gear
Default Re: bad ball joints (scorpion)
Thanks, sounds like I'm getting the wrong part. Really didn't want to go to the dealer, but sometimes you have no choice. Kinda dissappointed that a corvette specialty outfit doesn't know the difference.
To bad ball joints
