Clutch not fully disengaging
Old Jan 13, 2003 | 03:43 PM
kwd1's Avatar
kwd1
Default Clutch not fully disengaging
Hi all,
Sometimes in the morning I notice that when I put the trans into
reverse, the car rolls backward slightly. It does it right as the shifter is going into gear. Have also seen it going into first.
I guess this is due to the clutch not fully disengaging with the pedal all the way down. Is there an adjustment I need to make?
tia
Ken
Old Jan 13, 2003 | 05:12 PM
tpi 421 vette's Avatar
tpi 421 vette
Default Re: Clutch not fully disengaging (kwd1)
You are probably low on fluid. You can add brake fluid to the clutch master to get you by, but you probably have a leaking clutch master cylinder, leaking clutch slave cylinder, or both.
Old Jan 13, 2003 | 07:16 PM
bogus's Avatar
bogus
Default Re: Clutch not fully disengaging (tpi 421 vette)
:iagree:
you have to remove the ECU to get to the clutch master.
Old Jan 14, 2003 | 09:43 AM
kwd1's Avatar
kwd1
Hi,
My clutch hydrolic fluid is topped off...
Thinking about symptoms some more, I'm not certain that it
the clutch isn't disengaged because with the clutch in and
shifter in gear, the car doesn't move or try to.
It just happens right as the shifter is going into gear. Its very
slight, the car rolls backwards about 1/2".
Also it doesn't happen every time.
Is there any way that putting trans into gear cause a
small torque on the driveshaft?
Ken
Old Jan 15, 2003 | 11:14 AM
kwd1's Avatar
kwd1
Hi,
Ken
Old Jan 15, 2003 | 01:31 PM
Thumper's Avatar
Thumper
Cruise-In II Veteran
When I put mine in gear it moves too. I think that might be normal. I don't know why it does it and it's only about 1/2 inch so I never worried about it to much.
To Clutch not fully disengaging
