Crank but no start issue
Old Feb 22, 2023 | 10:11 AM
Willie b's Avatar
Willie b
1st Gear
Default Crank but no start issue
Hello i am a owner of a 1986 c4 corvette. This corvette was a car that sat for quite some time ( during winter months ) in michigan. It now has a crank but no start issue. Wondering if anyone has any helpful tips. I did notice the connection to the starter housing as being extremely hot and almost a cherry red when ignition is being turned over. Since i have replaced the entire starter unit. I have replaced the fuel pump, and fuel pump filter. I have also done 6/8 spark plugs and wires as the #8 spark plug especially is hard to get to with the exhaust in the way. Here i have a photo of the car symptoms. I did originally spray starter fluid in the car it started but then immediately stalled out! This is a vehicle i was able to pick up for a bargain. It has run before with no problems besides a misfire at that time. That i could notice myself. But I am not a certified mechanic ither. I know only the basics.
File Type: mov
File Type: mov
