American Racing Headers question
Old Feb 22, 2023 | 04:08 PM
AZSP33D's Avatar
AZSP33D
Default American Racing Headers question
Ordering a set of American Racing Headers for the C4, and I was wondering, does it always come with the EGR tube fittings? Everybody has generic pictures for either 88-91 or 92-96... so called ARH, gave them a part number for the 1992+ with Cats and they said it comes with the EGR. What's the key to ordering these with out the EGR? Prefer cats (not a must) and no EGR (that's a must) and 3" full dual system and that's why I ordered the 92+ as I didn't want to go down to 2.5" at the end. Lot of you guys have these headers, so I thought I'd ask.
Old Feb 22, 2023 | 05:53 PM
C409's Avatar
C409
My ARH Headers have NO provisions for the A.I.R. fittings ... they are 1 3/4" stepped to 1 7/8 with a 3" collector ... I do not have a part # .
Old Feb 22, 2023 | 07:01 PM
dizwiz24's Avatar
dizwiz24
My only 2 gripes on ARH is that
1. They are needlessly heavy. I know they brag how tough they are built but i could really care less about ‘extra thick mounting flange bar’ when im trying to compete with lightweight alum block ls motors
but im sure some old man out there ‘wants em heavy’ bc he feels that makes them higher quality.
2. next, they didnt clear the swingouts of my canton road race oil pan , like my TPIS 1 3/4” headers did
i had to use spacers to space them off the head slightly to get the down tubes to clear the swingouts
otherwiae good
i had mine swain tech coated (thru arh) and they also added some extra o2 bungs for wide base sensors
Old Feb 23, 2023 | 09:08 AM
djpink889's Avatar
djpink889
The LT1 headers have a single threaded bung for the AIR setup, not EGR. You can easily plug them if ARH won't make a set without. The port is small unlike the L98 setups.
Old Feb 23, 2023 | 10:39 AM
383vett's Avatar
383vett
I've got the same headers Robert has. Just call AFR and have them give you the part number for what you want. Not the other way around.
Old Feb 23, 2023 | 06:02 PM
AZSP33D's Avatar
AZSP33D
Thanks everyone, got it settled, wish they had separate part numbers for different configurations so this wouldn’t be a PITA. ARH wasn’t very helpful to be honest, I was talking with a sales guy and since I was ordering from Summit to use my 10% SCCA membership discount, he probably didn’t want to put too much effort into it, can’t blame him.
Old Feb 23, 2023 | 06:07 PM
AZSP33D's Avatar
AZSP33D
That might be helpful for me if they are tucked in close as I don’t have the kickouts and would like to move the engine 1/4” to the right (with the motor plate).
Old Feb 23, 2023 | 09:57 PM
95LT1Z28's Avatar
95LT1Z28
I installed ARH long tube headers on my 94 Vette last winter. Here is the information and part # I used for no emission ARH long tube headers on my 94 Vette...CORVETTE C4 AMERICAN RACING HEADERS
SKU: C43434WC
Options1 3/4" Primaries- Non-Catted X-Pipe- C43434NC
Hope this helps you out!
Jeff
ARH long tube headers 1994 Corvette
Old Feb 23, 2023 | 11:26 PM
AZSP33D's Avatar
AZSP33D
Thank you Jeff
Old Feb 24, 2023 | 07:00 PM
C409's Avatar
C409
ARH has nice pictures on their website .
In spite of all of the installation "annoyances" ... these headers out performed the Hookers that I had on before the ARH's ... I picked up about 7-8 hundredths in my 60' times and about a tenth in the 1/8 mi. ... it doesn't help that the C4 chassis is pretty tight in the bellhousing and firewall/frame areas , but they're worth the hassle if you drag race your car .....
Old Feb 24, 2023 | 10:52 PM
383vett's Avatar
383vett
They were quicker than Hooker 2151s by one and a half tenths in the quarter on my car.
Old Feb 25, 2023 | 07:33 AM
dizwiz24's Avatar
dizwiz24
Yeah they are 1 7/8 stainless steel while my beloved tpis ones were 1 3/4” steel
so i guess of course they are gonna be heavier
i was also told the tpis ones werent equal length, whereas the arh ones are
spark plug changes were easier on the tpis ones
Old Dec 13, 2024 | 10:49 AM
VetACU1's Avatar
VetACU1
Default ARH headers
I am installing on my 95 convertible (6-speed)
had all 5-pieces of (no cats) coated at jet hot,
drivers side fits with oil filter although the collector is touching the oil filter, tried a hi torq starter from Ecklers that doesn’t fit convertible 94,95&96,
trying to source a mini starter, not having much luck.
Old Dec 13, 2024 | 11:00 AM
VetACU1's Avatar
VetACU1
Default Arh
SKU: C43434WC
Jeff
those are the same that I am putting on my 95 convertible six speed,
drivers side fits but touches the oil filter,
and I am trying to source a mini starter with no luck, is your car manual? Where you able to use your stock starter?
Old Dec 13, 2024 | 11:56 AM
AZSP33D's Avatar
AZSP33D
I have the ARH since I started this post a while back, couple of tips... use the Remflex type gaskets (they are badass and have a little bit of thickness to them) and for the oil filter, use a different adapter (slightly offset) or shorter filter.
For the starter, sent you a message, as I went through a starter ordeal back in 2021 and came to some conclusions that the aftermarket starter manufacturers didn't realize at the time:
https://www.corvetteforum.com/forums...post1608411596
Old Dec 14, 2024 | 06:38 AM
95LT1Z28's Avatar
95LT1Z28
I had my stock starter and did not have any clearance issues. Now, the O2 bung on the driver side header was welded in at a bad angle and made the O2 sensor almost rub the bell housing on my 6speed car. I would have to loosen all the header flange bolts to swing out the header to replace that O2 sensor. That was my biggest pain with install.
Jeff
Old Dec 16, 2024 | 10:28 AM
dizwiz24's Avatar
dizwiz24
I want to post a follow-up to my issues with the ARH 1 7/8" headers NOT clearing the swingout of my commonly used Canton Road Race oil pan.
On my next build (I re-used these headers), I was able to dent one of the tubes on the drivers side and get it to clear without using spacers. Denting it wasnt easy either.
I dont recommend header gasket spacers, as I did get burn-thru of the exhaust headers gasket on the center 2 tubes thin divider wall.
To American Racing Headers question
