C100 Connector
Old Feb 25, 2023 | 07:49 PM
johnfin's Avatar
johnfin
Default C100 Connector
Anyone ever look inside their C100 connector (drivers side harness). Mine looks like its full of tar.
Old Feb 25, 2023 | 08:06 PM
JD1964's Avatar
JD1964
They put that goop in there from the factory. It’s designed to keep moisture out for corrosion protection
Old Feb 25, 2023 | 09:00 PM
johnfin's Avatar
johnfin
After 40 the stuff has become hard. I was thinking aboit using contact cleaner on it then packing it with dielectric grease. Or just clean it and leave it dry.
Old Feb 26, 2023 | 09:53 AM
FostersPerformance's Avatar
FostersPerformance
Originally Posted by johnfin
After 40 the stuff has become hard. I was thinking about using contact cleaner on it then packing it with dielectric grease. Or just clean it and leave it dry.
I cleaned up the excess on mine. Manually checked and cleaned the contacts (took awhile). Used a little bit of dielectric on it, plugged back in and tightened. No issues.
To C100 Connector
