hi pitched squeal
Old Jan 13, 2003 | 08:22 PM
vsilken's Avatar
vsilken
3rd Gear
Default hi pitched squeal
I'm hearing this high pitched squeal from the underbed of my 1993 ragtop. At first I thought it was worn brake pads, but I replaced them to be safe and the squeal is still there!!!! I should have known it was something else as the noise occurs while the car moves, whether or not I have the brake depressed. The car is running fine, and the noise doesn't occur while the car is stopped, even if I rev in neutral. Anyone have any ideas? Help!
:smash:
Old Jan 13, 2003 | 10:54 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default Re: hi pitched squeal (vsilken)
Does the car make the sound when coasting, while accelerating, or both?
Old Jan 14, 2003 | 12:24 PM
vsilken's Avatar
vsilken
3rd Gear
Default Re: hi pitched squeal (flyersfan1088)
hey, thanks in advance.
it makes the squeal when coasting and accelerating.
Old Jan 14, 2003 | 03:35 PM
Mike's 86's Avatar
Mike's 86
Try jacking it up then running it in gear and see what happens, but be sure to use jack stands. good luck :cheers:
To hi pitched squeal
