What headers will work with AFR heads?
Old Jan 13, 2003 | 09:19 PM
MagRed_04's Avatar
MagRed_04
Default What headers will work with AFR heads?
I wanted to purchase Hooker 2149's, but found out from their web site that they will not work with AFR angled heads... Any suggestions?
:banghead:
Old Jan 13, 2003 | 11:30 PM
vader86's Avatar
vader86
Default Re: What headers will work with AFR heads? (Vette_Crazy)
they will work with the L98 angled plugs
Old Jan 13, 2003 | 11:46 PM
Caboboy's Avatar
Caboboy
Default Re: What headers will work with AFR heads? (vader86)
:yesnod: L98 Angle Plug Heads I have the combo.
Old Jan 14, 2003 | 06:44 PM
MagRed_04's Avatar
MagRed_04
Why do they state that notation then? :confused:
Old Jan 14, 2003 | 06:52 PM
tpi 421 vette's Avatar
tpi 421 vette
Their bigger heads (220's and I think the 210's) come with what they call a bowtie spark plug angle. They angle the spark plugs down more, causing the spark plug to hit the header tube. You can get the L98 spark plug angle optional on the 210's and smaller heads, and they will work fine with any header.
Old Jan 14, 2003 | 09:18 PM
MagRed_04's Avatar
MagRed_04
Default Re: What headers will work with AFR heads? (tpi 421 vette)
One more question... What Y pipe will I need for my '85? I see that the one they reccomend the (16720) is slated for '86 and up...
Old Jan 14, 2003 | 11:09 PM
vader86's Avatar
vader86
The difference is in the flange on the converter, you must buy the 86+ Y-pipe but you will probably have to weld the flange from your stock converter to it.
To What headers will work with AFR heads?
