Fuel Lines!!
Old Mar 6, 2023 | 04:37 PM
PkStreetSoldier's Avatar
PkStreetSoldier
Default Fuel Lines!!
I bought my 1984 Corvette over a year ago I have been doing body work and the interior for the last 6 months almost ready for paint soon Well anyways I have rusted fuel lines I am doing a retro restoration. I am putting a Holly Brawler 650 CFM carburetor on the car this week. I want to put all new braided fuel lines in the car. I was wondering if anyone has done this and what size the lines should be good for the 650 CFM carburetor, I am putting a Cam Shaft in the car in a few weeks. (Comp cams 12-242-2) a quick google search and it says the C4s need 25 feet of 3/8 fuel line from gas tank to the fuel filter then I am not sure how it goes after the fuel filter. If anyone has any advice on how I should run the fuel lines maybe straight to the filter, then from filter to the carb? or should I continue all those other things under the hood that the fuel goes through? Not sure if anyone is going to understand what I am trying to say. Also, what fittings would I need to connect the line to the filter and up from the filter up into the motor or is just a clamp type of set up. should I also change the filter to match the braided line set up basically want fuel line size the length the type of fittings. Sorry if there is any confusion.
Old Mar 6, 2023 | 08:48 PM
Phobos84's Avatar
Phobos84
I did PTFE braided feed and return lines in my 84 for my LS swap. I used a 8an feed and 6an return. I'm not sure what size you would need being that you're going with a carb. But I used one of the eBay kits with fittings and it worked extremely well. No leaks and it was easy to put together. I ran the feed and return on the passenger side. The hardest part was finding a bulkhead fitting that I was happy with at the sending unit.
this is the kit I used.
Here
