Need some advice on timing chain.
Old Jan 14, 2003 | 01:21 PM
RadPolo96's Avatar
RadPolo96
Default Need some advice on timing chain.
I talked to Jeff Kopp today to order the rest of my parts for hot cam. Th subject of the timing chain came up. He said that is should upgrade if I plan on staying above 6000rpm for sustained amounts of time. This car is my daily driver, I dont really plan on taking it to the track. On the other hand I do plan on doing other mods and I do drive some what aggressive. What would you guys suggest?
Old Jan 14, 2003 | 02:29 PM
Half Fast's Avatar
Half Fast
Default Re: Need some advice on timing chain. (RadPolo96)
The LT4 heavy duty timing set is a good upgrade for a 96 if your raising your shift points. Much better than the stock LT1 chain. Your mileage will be a factor also.
Old Jan 14, 2003 | 04:52 PM
SPD DMN's Avatar
SPD DMN
Cruise-In I Veteran
Cruise-In II Veteran
Default Re: Need some advice on timing chain. (Half Fast)
I ran a stock chain in my original 396 for several thousand miles without a problem with shift points a little over 6K. I would not worry too much about upgrading it.
To Need some advice on timing chain.
