700r4 not shifting into third
Old Mar 21, 2023 | 11:08 AM
kitttransam's Avatar
kitttransam
Default 700r4 not shifting into third
I’m sure this has been covered many times. So suddenly my tranny wouldn’t shift into third gear. This was right after getting on it. So the thing is I rebuilt the tranny several years ago. Did most of the common upgrades. Modified the 3-4 clutch pack to the seven clutch stack like the atsg book shows. And used the trans go shift kit from probuilt. It’s been pretty reliable until now. Fluid doesn’t smell burnt. I tried playing with the tv cable thinking maybe the valve was stuck. Still wouldn’t shift. I got it to shift into 3rd and 4th one time by shifting manually. But it only did it once. Couldn’t get it to do it again. It just doesn’t seem like it’s slipping. Is it possible that it’s the governor? Or a sticking valve?
Old Mar 21, 2023 | 04:38 PM
kitttransam
Well when I checked the fluid on the stick it didn’t look dirty. I pulled the governor cover to check the governor and different story fluid looks dark. So a little worried now. I’m going to check the valve body first before pulling the tranny. Really don’t want to do a tranny job again but might have too.
