Identify & source this bushing on rear leaf spring
Old Mar 21, 2023 | 06:44 PM
Supermutt's Avatar
Supermutt
Default Identify & source this bushing on rear leaf spring
Thanks in advance for any help you can give me on this
as titled, not sure of correct nomenclature of the rear leaf spring bushing, also need to source them.
Also what i believe is the connector for the wheel speed sensor all 4 are falling apart, plan is to seperate unplug and shrink wrap each wire individually.
This connector is the best one, the other 3 wires/ clips are visible.
Old Mar 21, 2023 | 07:26 PM
s carter's Avatar
s carter
Auto Zone can have them quickly I have had a set on my car for 5 years and still going strong
https://www.autozone.com/suspension-...23r/354438_0_0
Mirrock Corvette in Saltsburge has several
https://www.ebay.com/sch/i.html?_dkr...speed%20sensor
Old Mar 21, 2023 | 08:16 PM
Supermutt's Avatar
Supermutt
Huge Thanks,
Bushings ordered, website said march 25th, man i hope so. Cars up on the quick jacks work has started
Old Mar 21, 2023 | 09:24 PM
s carter's Avatar
s carter
I will admit that I re-used a few of the factory washers because GM used cupped ones
Old Mar 22, 2023 | 10:00 AM
Whaleman's Avatar
Whaleman
Not to hijack but if I install the Autozone bushes can I put the nut in exactly the same place and be OK? Thanks, Dan
Old Mar 22, 2023 | 12:47 PM
s carter's Avatar
s carter
The idea is to bring the retainer nut to the point where the Cotter Pin hole is +- center of groove of Castle nut,I guess if you want a little extra tension you could add a washer or two.
But I don't think that is needed, the new bushings are much thicker and denser than most worn out bushings.
Old Mar 22, 2023 | 03:09 PM
Whaleman's Avatar
Whaleman
Thank you. I understand. I was confused by th op's double nut. I am out of town and can't look at mine. Dan
Old Mar 22, 2023 | 04:02 PM
MatthewMiller's Avatar
MatthewMiller
Just to add to the info already presented, I don't think the stock rubber bushings are available at all anymore. These Energy Suspension pieces are fine: it's what I used on mine.
Old Mar 22, 2023 | 04:50 PM
s carter's Avatar
s carter
Auto Zone and most of the box parts stores have a few choices, including a plain black rubber.
https://www.autozone.com/suspension-steering-tire-and-wheel/leaf-spring-bushing-bolt/p/energy-suspension-leaf-spring-bushing-bolt-3-2123g/354437_0_0
Old Mar 22, 2023 | 06:22 PM
Whaleman's Avatar
Whaleman
I think all the Energy Suspension bushings are polyurethane and not rubber. I don't believe anyone makes rubber ones for our cars. Dan
Old Mar 22, 2023 | 06:27 PM
s carter's Avatar
s carter
It really doesn't matter rubber or polyurethane it's not a Hi-Tech part infact it's 1 step up food chain from a Hockey Puck
(Hockey Puck would split under load in time) did a Red Neck Body lift on a truck once they cracked in a year.
Old Mar 22, 2023 | 09:08 PM
MatthewMiller
Which is why I said it's fine to use the ES parts.
The urethane bushings will break down and fall apart in time also. In this application they are under a significant load all the time, and they are exposed to road conditions and some exhaust heat. When I bought my car I had to replace the ES bushings in the rear spring for that very reason. Luckily they are cheap and easy to replace.
Old Apr 4, 2023 | 08:00 PM
Whaleman's Avatar
Whaleman
I just did this yesterday with the Energy Suspension bushes on my 96. I was actually surprised how good my original ones looked. The new ones seem stiffer. Pretty quick to change them. Dan
To Identify & source this bushing on rear leaf spring
