Need help!!!!!
Old Jan 14, 2003 | 06:25 PM
TomsZ06's Avatar
TomsZ06
Default Need help!!!!!
Somehow my interlock reverse **** on my 1992 6 spd shifter decided to quit on me last night with absolutely no warning. The black plastic **** that is directly below the leather covered shifter has no more spring action and is just going up and down without any feeling of resistence. Before, when I lifted it I felt resistence and when I let it go it would travel downward about 1/2 inch. So far I have been able to remove the plastic piece that shows the gear pattern but that is as far as I was able to go. I can't figure out how to remove the leather gear shift **** so that I can try and figure out what actually broke. Any help would be most appreciated. :confused:
Old Jan 14, 2003 | 08:14 PM
don hall's Avatar
don hall
Default Re: Need help!!!!! (TomsLT1)
The Chilton manual suggests prying out the shift **** release button and the rivet pin, which should be located just under the shift pattern plate. Unscrew the **** (cc). Pry out the collar retainer, and lift off the collar. Remove the screws attaching the console cover. Remove the shifter boot bolts and the shifter boot.
Old Jan 14, 2003 | 08:35 PM
TomsZ06's Avatar
TomsZ06
Default Re: Need help!!!!! (Oldman)
I figured it out. There is a 1/16" set screw right above the black plastic **** that screws into an inner shaft with an indented recess. Once I tightened this set screw it locked into the inner shaft and now I have reverse!
Thanks :D
Old Jan 14, 2003 | 08:39 PM
don hall's Avatar
don hall
Good for you........that was too easy. :steering:
To Need help!!!!!
