Hvac wiring help
i need info on the brown one and the white one if possible. Car is an 1984 model.
Thanks for any help!
These are the connectors i need help with
This is a photo of the front, so you know what hvac i have
my account is new here, so it definitly cannot pm. I can however link you an unused email address i don’t mind being public, if it means access to an FSM for that car. It would help me sooo much, as i can’t find stuff for it other than stuff for all c4’s
anyways, here’s the email: Mydnyte.corvetteforurm+1984@gmail.com
EMAIL IS MISSPELLED.
Using a multimeter i've done a basic test on the pins and found the following information:
MODE | Pin connection
Off | None linked
Max | 5-4-3 linked, 1-2 linked
Norm | 5-4-3 linked, 1-2 linked
Bi | 5-4-3 linked, 1-2 linked
Vent | 5-4 Linked
heater | 5-4 linked
defrost | 5-4-3 linked.
again, pin 1 is far from the white vacuum connector, 5 is close.
My question now is, how does the ac compressor turn on, if there's no wires connected to 1 and 2? as well as any idea on what pin 3 does?
For reference, I'm asking a lot of detail due to the fact that I will almost certainly be re-wiring this entire car from the ground up. (standalone ecu)
Off | None linked
Vent | 5-4 Linked
heater | 5-4 linked
Power from pin E connects to pin C when "Max", "Normal", "Bi-Level" or "Defroster" are selected.
1=A, 2=B, 3=C, 4=D, 5=E
Your measurements match except for "Bi Level" that should be 5-3 linked.
