Re: C4 Front Hub Bolts Torque Specifications Needed (robo12)
My Haynes reads "Hub to bearing-to-knuckle bolt and nut is 46 Ft-lbs. The book covers 1984-96. Did this on my 94, be careful with brake line and ABS plug-in. I found metal splinters on plug, they were holding like the plug was a magnet. Would suggest you at least buy Haynes book for your Corvette, it gives you a little heads-up on these jobs. Also I went with the 94 Firebird hub and bearing at Advance auto for $139.00.
