Throttle Body Air Foil
Old Apr 6, 2023 | 09:53 AM
ellis1969's Avatar
ellis1969
Default Throttle Body Air Foil
During moderate shifting, the throttle stuck at about 4500 rpm. Turns out that the air foil had come loose and jammed the intake butterflies. Shut it down, removed rubber intake line, and re-install the foil. Works fine now, but word to the wise, shut it down promptly, if this happens to you!
Old Apr 6, 2023 | 12:51 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
Where did fastener that holds it in go ?
later,Tiny
Old Apr 6, 2023 | 02:51 PM
ellis1969's Avatar
ellis1969
There is a bolt about 3mm dia. and about 5 cm long, that goes through the upper portion of the throttle body into a threaded hole in between the two main plenum air orifices. You need a 7/32 Allen wrench to tighten it. The air foil was probably standard on my1989 convertible, since it was there when I got it in 1992.
Old Apr 6, 2023 | 03:15 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
No engine came with an air foil. Someone added it.
I'm with 1800 wing....where'd the bolt go? Did it stay in the foil, somehow?
Old Apr 6, 2023 | 04:13 PM
Incorvettei's Avatar
Incorvettei
Does an air foil actually do anything?
Old Apr 6, 2023 | 04:21 PM
slammin's Avatar
slammin
That question is up for debate. I would be concerned about the bolt that mounts it.
Old Apr 6, 2023 | 07:10 PM
ellis1969's Avatar
ellis1969
Fortunately. yes! When I pulled the rubber "pipe" from the filter housing, the foil and bolt were in there. Maybe luck is better than skill?
So I am already, 11 to 50 higher HP with the airfoil?? I don't believe anything with less than 60-80 hp, and am real skeptical of any of those.
Old Apr 6, 2023 | 07:21 PM
slammin's Avatar
slammin
Looking at the stock throttle body, one would think the airfoil would improve the air flow. Most of the guesses I've read speculate just a few HP. One thing is for certain, I'd put some loctite on the screw.
Old Apr 6, 2023 | 07:49 PM
ellis1969's Avatar
ellis1969
Oh, Yes! Lock-Tite and enough twist to tighten without stripping the AL treads.
Just glad I wasn't showing off and speed-shifting.......nearer to red-line!
Old Apr 6, 2023 | 10:18 PM
1800Wing's Avatar
1800Wing
Flatulent Dwarf
With luck like that I’d be buying some lottery tickets….
later,Tiny
Old Apr 6, 2023 | 11:57 PM
red86silver78's Avatar
red86silver78
I had one on my engine I noticed it really blocked the passage to the iac valve and also the passage that goes to the passenger side valve cover for the pvc system to work how it was designed. Best mod I ever did was remove it and trow it in the trash. Just glad it was given to me and I never spent money on it. The car seemed to idle much better with it removed.
Old Apr 7, 2023 | 09:09 AM
ellis1969's Avatar
ellis1969
Now that I know the air foil wasn't stock, and of questionable (no!) value, it will become an anchor for a very small boat.
Old Apr 8, 2023 | 05:41 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
The air foil does do something, but it is very minor.
I had an '87 with one (and a few other minor mods). With the stock chip it had a slight stumble on initial acceleration. I removed the air foil and the stumble was gone.
I changed the chip to an SLP chip and then reinstalled the air foil. The stumble was still gone.
So my conclusion is that it did make a difference in airflow as evidenced by the stumble appearing. However, there was no noticeable performance increase. So it does do something, but not really helping performance.
The real concern is if the bolt comes loose and goes into a cylinder you could loose an engine. If you decide to take that risk, make sure you use loctite on the threads.
Good luck.
Old Apr 8, 2023 | 05:44 PM
ellis1969's Avatar
ellis1969
Definitely!
Old Apr 8, 2023 | 08:49 PM
64Scout's Avatar
64Scout
It lightens your wallet
To Throttle Body Air Foil
