I Would test a much lower setting to see if it functions as intended. For example set 1st to 4000rpm and then smack 4000rpm and see if it actually does anything.
If so maybe the momentum of the engine carried it to 6400. Unlikely but its the only way I can think of to reach a higher rpm without fuel.
