Ignition control module
Old Apr 16, 2023 | 05:29 PM
NARDA1's Avatar
NARDA1
2022 C4 of the Year Finalist - Unmodified
Default Ignition control module
Is there supposed to be any heat insulation between the cylinder head and the heat sink that the ICM mounts to?
Old Apr 16, 2023 | 10:00 PM
Patsgarage's Avatar
Patsgarage
I use heat sink compound.
Old Apr 18, 2023 | 06:51 PM
NARDA1's Avatar
NARDA1
I know about the heat sink compound. I was asking if there should be some type of insulation between the cylinder head and the heat sink to prevent heat transfer from the cylinder head to the heat sink.
Old Apr 18, 2023 | 09:20 PM
Whaleman's Avatar
Whaleman
The heat transfer compound is installed to HELP heat transfer from the hot ICM to the cooler cylinder head. Dan
Old Apr 19, 2023 | 07:36 AM
sflier's Avatar
sflier
This is what you need: Super Lube 98003 Silicone Heat Sink
Amazon Amazon
To Ignition control module
