Headers with '85 converter...
Jan 15, 2003 | 07:01 PM
Are there any headers that will bolt up to my '85 converter? I see most systems are designed for '86-'91?
Jan 15, 2003 | 07:51 PM
Re: Headers with '85 converter... (Vette_Crazy)
I think TPIS is the only one to make a bolt-up header and Y-pipe for the 84 and 85.
Jan 15, 2003 | 09:19 PM
Hooker headers and the Hooker Y pipe with a 4 bolt flange welded on, to bolt to your converter, will work like a charm. 1984's and 5's are the same in this respect. Good luck, and...
RACE ON!!!
Jan 15, 2003 | 11:07 PM
All the L98 systems will bolt up correctly at the heads, but its at the converter flange that the difference lies.
You have to weld the flange from the 85 onto the new headers so it will fit.
Jan 15, 2003 | 11:18 PM
Hookers with the 86-91 Y pipe welded on my 85 style cat
[Modified by corvette0096, 8:19 PM 1/15/2003]
Jan 15, 2003 | 11:22 PM
Cruise-In V Veteran
Re: Headers with '85 converter... (Bluevette85)
TPIS bolts right up when you use their Y !! :yesnod:
[Modified by 85vet, 11:23 PM 1/15/2003]
Jan 16, 2003 | 11:59 AM
The TPIS headers bolted right up and fit well. They Y-pipe fits well around the 4+3 fluid pan, but I am unsure about fitment around an auto. I recommend some heat reflective tape or sleeving on the fuel line where it passes close to the pass side header and you will have to zip tie a few of the wiring looms out of the way. Other than that it was fairly painless.
Jan 16, 2003 | 05:28 PM
TPiS sells them.
Greg
