First post / 1985 surging idle
Old Apr 20, 2023 | 08:01 PM
Hellman's Avatar
Hellman
4th Gear
Default First post / 1985 surging idle
Hello everyone, first let me say Thank you, some of you have helped me a lot over the last few months getting this 1985 barn find running. I am having a ongoing idle issue surging from 550 to 900 in park ( automatic) along with a hesitation when giving heavy throttle. Since this car was sitting for a few years I have started replacing known problem parts that I could test or see needed replacing- IAC, TPS, EGR, injectors, fuel pressure regulator, O2 sensor, fuel pump and filter, oil and filter. The car is running rough but it's a set in the right direction since it didn't run last month. The car starts up idles high 1000-1200 then drops to 550 and enters closed loop it begins to surge. I did a smoke test thinking it was a vacuum leak but found nothing. I have codes 15, 23, 44 both sensors should be here this weekend but not sure why 44 -lean exhaust is popping up. Fuel on the rail is 42psi with 24LB injectors.
Any tips on what i should do next?
Old Apr 21, 2023 | 09:08 AM
Hellman's Avatar
Hellman
4th Gear
Default Options?
Does anyone have tips or ideas what could be wrong?
I understand this is a topic discussed many times in the past but I have gone through the ideas on previous boards to no success.
Old Apr 21, 2023 | 09:57 AM
2011KLR's Avatar
2011KLR
Wish i could help you. Ive asked an iuneplied to idle question too.
Best guess, and one im going to investigate for myself soon.... what about the EGR solenoid and the hoses downstream from it? Maybe... it is opening and introducing air through a line leak that wont show itself whem the enigne is not running.
Old Apr 21, 2023 | 10:24 AM
Hellman's Avatar
Hellman
4th Gear
I also thought about this. One thing I did notice was if I pull the vacuum off the passenger side plenum going to the EGR solenoid the idle becomes steady but then throwing the code 32 = EGR failure
I do not know if there's a way to test the EGR solenoid but seams to be a problem. Also waiting on a new coolent sensor since I have code 15 pop up randomly. I feel like I'm just throwing parts at this thing and we all know that's not the way to go.
Old Apr 21, 2023 | 02:26 PM
2011KLR's Avatar
2011KLR
Lets both throw caution to the wind and replace EGR solenoids. 😁
Old Apr 21, 2023 | 09:52 PM
LiveWire1's Avatar
LiveWire1
My 85 had a wandering idle like yours, and I finally fixed it this past weekend. It turned out to be a single vacuum hose that I had neglected to replace last year. I replaced all the soft vacuum hoses with new silicone vacuum hoses, except for the one from the cruise control unit to the brake and clutch pedals. It was mostly missed because I wasn't looking forward to doing a session of Corvette yoga, under the steering wheel. But, the wandering idle was really bugging me this year, so I yanked that thing through the firewall, with the new hose attached to it. When I put the old hose on my hand vacuum pump, and applied a bit of vacuum to it, it collapsed to about the thickness of a piece of paper. At 38 years old, those black rubber hoses are done, and all need to be replaced. The plastic ones are fine, as are the fittings. But this is the cause of the idle problems, at least for me.
Old Apr 22, 2023 | 09:03 AM
Hellman's Avatar
Hellman
4th Gear
I like the idea and have spare vacuum line in the garage. This is now my project for today. Thanks for the idea
To First post / 1985 surging idle
