1987 C4 Cruise Control Blues - Brake Switch
Old Apr 20, 2023 | 11:16 PM
Vwaggs's Avatar
Vwaggs
Cruising
Default 1987 C4 Cruise Control Blues - Brake Switch
So My cruise is out.go figure. I have no dash light. Vacuum lines all look good. The vacuum brake switch is functioning. The brake light combo switch operates the brake lights. The upper plug, which I understand is also for the cruise, has NO power to either side.Fuses are good. What else do I check? If my stalk switch is bad, what are the wire colors I need to take off the column to run a flush mount power and set/accel switch on panel? Thanks in advance. Vacuum all appears good. So I opened the switch. The lower and upper parts are separate and I have no juice from either side wire. I'm guessing this comes out of the stalk. I'm thinking I can add power here to find out if the cruise works. If anyone can post a diagram so I know what the wires off the column for the cruise are and what they are to the dual brake light/cruise switch I'd appreciate it.
