Help identifying headlight motor
Reason for asking: My headlights keep trying to move after they have reached their end position when raising and lowering. I got ready to change the gears and already have the 1986 white gears with the black rubber parts when I noticed those motors rather look like the later ones.
Can anybody pls confirm? I don´t want to take everything apart to find out I have the wrong parts.
Also the later mount a little different in other places, here is links with some pictures so you can compare the difference between all the styles
https://corvetteparts.com/item/motor-right-headlamp-rebuilt-1984-1987
https://corvetteparts.com/item/motor-right-headlamp-rebuilt-1988-1990
https://corvetteparts.com/item/motor-right-headlamp-rebuilt-1991-1996
What did I use for making my own pellets? Since I know that some guys from a Ford forum even used hex nuts on their window motors (same design) I figured making something myself from what I have in my junk drawer should work. I remebered the hot melt glue sticks I have and thought they might just be about the right size. They were dead on at 11mm (7/16")! I cut 6 pieces of approx. 5/16" or 3/8", used some sand paper to smooth out the edges and rough cuts, put everything together - headlamps work great again.
If you go to the Box Parts Stores on the Motor Mite HELP odd things display I have seen Teflon bushings for something for a Ford. Or you can get them with the gears, unless you have the bronze upgrade I always change the gears while I'm there
