Distributor play?
Old May 3, 2023 | 02:35 PM
mlm0's Avatar
mlm0
Default Distributor play?
1989 auto stock
When I take out rotor, and grab hold of the distributor shaft, I can move it about 1/4 inch each way. Is this too much play and if so, what will be the affect on engine performance, essentially at idle?
mike
Old May 3, 2023 | 02:45 PM
SH-60B's Avatar
SH-60B
Does it have mechanical advance?
Old May 3, 2023 | 03:02 PM
mlm0's Avatar
mlm0
No. Stock HEI computer controlled
Old May 3, 2023 | 03:21 PM
AZSP33D's Avatar
AZSP33D
The gear at the cam and the aluminum housing/shaft should be shimmed properly, but nobody seems to do it... Moroso makes a shim kit, and there should be a bronze washer in there also. I shim these for 0.003 for aluminum block and 0.005 for iron block... most of them have 0.030-0.040 new. If it's excessive, the gear walks up and down too much, so there are timing stability and wear issues. Mostly walks up as the oil pump takes a lot to turn.
To Distributor play?
