Headers with iron heads - does it work?
Old Jan 16, 2003 | 02:16 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Headers with iron heads - does it work?
I know both Hooker and TPIS have headers which bolt up to a C4 w/iron heads, but are there any problems due to the straight plugs? Do you have to do some grinding or how can you get around this problem?
:seeya
Old Jan 16, 2003 | 02:21 PM
vader86's Avatar
vader86
Default Re: Headers with iron heads - does it work? (FlyboyZR1)
As long as you get the headers with L98 angle plugs, youre straight.
Old Jan 16, 2003 | 03:46 PM
NUckINg FuTS's Avatar
NUckINg FuTS
Default Re: Headers with iron heads - does it work? (vader86)
I have hooker long tubes and have no issues with my iron heads. Some plugs are a biotch to get in/out but it's doable :cheers:
Old Jan 16, 2003 | 03:51 PM
Phobos84's Avatar
Phobos84
Default Re: Headers with iron heads - does it work? (NUckINg FuTS)
With my Edelbrock heads and Headman headers I have to pull the headers out about 1/4 inch to get the plugs on or off.
Old Jan 16, 2003 | 05:21 PM
Greg Johnson's Avatar
Greg Johnson
I used the TPiS coater headers on my '85 with iron heads. It was a pretty easy install. The only problem I had was the #7 plug was too close the header and would arc. I solved this by unscrewing the tip of the plug (where the boot slips on) and cutting 1/8" off the threaded rod. Also, I filed off the cap by 1/8" before threading it back on. I was using Bosch platinum plugs which are the shortest ones I could find. Anyway, this solved the problem.
Greg :D
[Modified by Greg Johnson, 4:23 PM 1/16/2003]
Old Jan 16, 2003 | 10:02 PM
oldace84's Avatar
oldace84
St. Jude Donor '04 & '05
Of course it will....some problems around plugs, but not insurmountable...in other words it can be done.....
:steering:
Old Jan 16, 2003 | 10:12 PM
VetteNoob's Avatar
VetteNoob
Default Re: Headers with iron heads - does it work? (Greg Johnson)
Greg :D
:iagree: Only Im using the Accel header short plugs. I think they were like 1/16" shorter than the Bosch plugs. I too had to cut down the plug cap and then shaved some of the plug boot too. No problems yet. It is hard to get a good torque on some of the plugs though.
Old Jan 16, 2003 | 10:29 PM
FlyboyZR1's Avatar
FlyboyZR1
Default Re: Headers with iron heads - does it work? (VetteNoob)
Thanks. I e-mailed TPIS and they said the header will have to be clearanced on a few primaries. Do you lose any bottom end with headers? Also how many hours do they usually take to install?
Old Jan 16, 2003 | 11:24 PM
VetteNoob's Avatar
VetteNoob
Took me and 85WhiteZ51 about 5 hours to install just the headers and Y pipe. We did come across a problem and that added about an hour to the install. Here are before and after dynos with headers and ported/siamesed runners installed (in the after).
Before
After
Notice how the power curve flattened out with the headers and ported TPI installed. Plus I made a little more hp/tq across the board. The results were not as good as I had hoped, but they were still nice considering the how little I spent getting it.
Old Jan 17, 2003 | 09:26 AM
Greg Johnson
I probably lost a little off the line, but I never dynoed it or clocked it. When I put the Big Mouth and big tubes on later, there was a definite gain at the low end with the headers.
Greg
[Modified by Greg Johnson, 8:28 AM 1/17/2003]
To Headers with iron heads - does it work?
