Intake runner bolt sizes and specifications
Old May 7, 2023 | 05:59 PM
mvankley@aol.com's Avatar
mvankley@aol.com
3rd Gear
Default Intake runner bolt sizes and specifications
I have not been able to find the bolt specifications for the runners on my 1990 C4 L98 so I decided to make them available.
Pan head torx T40 black oxide
Hardness 10.9
Head diameter 15.30mm
11- M8-1.25 x 30mm
2- M8-1.25 x 35mm (upper end of runners on the bottom)
2- M8-1.12 x 40mm (inside)
4- M8-1.25 x 55mm (lower end of runners on the bottom)
I do not understand why a company like ARP does not sell these replacement bolts. I saw a used set on Ebay for $154.00
Old May 7, 2023 | 06:25 PM
WVZR-1's Avatar
WVZR-1
You're offering these for sale as a set? What about the M8 -1.25 X 30 stud? You need to correct the 3d item I believe to M8-1.25 vs M8 -1.12
Old May 7, 2023 | 06:29 PM
mvankley@aol.com
3rd Gear
They are not for sale. I was just giving information.
There are no studs for the runners on my C4 L98.
Old May 8, 2023 | 06:52 AM
mvankley@aol.com
3rd Gear
Below is the corrected information.
Hardness 10.9
11- M8-1.25 x 30mm
1- M8-1.25 x 30mm stud (for throttle cable bracket)
2- M8-1.25 x 40mm (inside)
Old May 8, 2023 | 10:23 AM
yakmastermax's Avatar
yakmastermax
Thanks for the info!!!
To Intake runner bolt sizes and specifications
