Acceleration problem
Old May 11, 2023 | 11:35 AM
Warriorofsun47's Avatar
Warriorofsun47
Cruising
Default Acceleration problem
Hello I have a 88 corvette I’ve changed my distributor, o2 sensor, fuel pump, fuel filter, coolant sensor, Alternator, battery, spark plugs and wires, and injectors I timed it to 6 degrees but the car still struggles to start and occasionally it struggles to accelerate I’m not sure what the issue is the only code I got was rich exhaust the exhaust is cut open right before the cats up front so idk if the o2 sensors sending a bad signal or what I’ve checked for vacuum leaks as well and nothing idk if anyone knows what could cause this I did find my fuel pump clogged yesterday cleaned it and put the sock back on since the last one fell off
Old May 11, 2023 | 01:45 PM
ex-x-fire's Avatar
ex-x-fire
Check fuel pressure and bleed down rate.
Old May 11, 2023 | 02:09 PM
Vets-Vet's Avatar
Vets-Vet
In open loop the O2 sensor is not part of the fuel calculation.
Old May 11, 2023 | 09:11 PM
78blueta's Avatar
78blueta
Did you change the fuel filter before or after finding the pump clogged and the sock off. New filter might be full of crap.
Old May 14, 2023 | 05:30 PM
lorenzo1987c4's Avatar
lorenzo1987c4
check IAC valve under the TB maybe
To Acceleration problem
