The 87 has started leaking fuel at the fuel filter. I replaced the in line filter and found another filter above it which is the culprit. This doesn't look stock, why would someone put a filter on the return line?
It was a "fix" (by dealer)
for fuel line noise that some experienced.
The TSB was to address previous years
Was also a BGR install on many/most 1987.
This guy an NCRS 'self proclaimed' ALL KNOWING maintains that it's not!!! It's been pointed out to him previously and actually a fellow NCRS guy that he knows has actually brought this issue up previously. I pointed it out to @IHBD/@DaveP85C4 I believe several years ago!!
It's been recorded in NCRS comments and maybe recorded 'in production' as early as 9/86.
I have the 'pdf and actually supplied it to IHBD/DaveP85C4 previously. He knows the fellow who has documented it!!
