Need help, car won’t start
Old May 19, 2023 | 10:45 PM
mlm0's Avatar
mlm0
Default Need help, car won’t start
1989 auto trans, stock
I remove my msd 6AL and reinstalled my original distributor the car started, but there was a scraping sound inside the distributor cap. At first I couldn’t tell what was making the noise, so I removed the distributor again I found the noise was from the rotor scraping against some areas inside of the cap where the plastic had not been trimmed after the cap was injected with what ever the cap is made of. In other words, terrible job of casting. I got rid of cap and bought new one. I re installed distributor at least 5 times, but engine won’t start. I have spark and I can smell the fuel, but it will not run. I’m sure I have the number one on top dead center. Af first I thought I might have distributor in 180 out, but I can’t believe I did it every time. Could it be the distributor is not seating completely and therefore is not engaging the oil pump to build up oil pressure and the oil pressure sensor is not letting engine fire?
Old May 19, 2023 | 11:37 PM
Kevova's Avatar
Kevova
Check fuel pressure, it should be over 41 psi. If you have a helper, spray flammable aerosol in throttle body if engine starts and runs , you have a fuel problem.
Old May 20, 2023 | 07:00 AM
s carter's Avatar
s carter
It ran with the poorly made cap so now we have same Distributor but new cap. My question is did you bring over the Ground Bridge when installing the new or bring over coil from old cap.
You would be surprised how many times that little piece of stamped steel gets left behind
Old May 20, 2023 | 08:00 AM
mlm0's Avatar
mlm0
Thanks for responding. I did install that piece of stamped steel
Old May 20, 2023 | 10:30 PM
78blueta's Avatar
78blueta
What kind of shape is the rotor in, could be broken and spark going down thru it to the distributor shaft.
Old May 20, 2023 | 11:33 PM
mlm0's Avatar
mlm0
Rotor is in good shape. I installed a clear spark tester in the number one plug wire and it shows I’m getting good spark. I borrowed a brand new distributor and will be installing it on Monday to see what happens
Old May 21, 2023 | 12:49 AM
stew86MCSS396's Avatar
stew86MCSS396
From: Liliha Bakery stuffing my face with coco puffs!
Well...you're getting spark but is the spark being delivered to the right cylinder at the right time??? Double, triple check firing order and as dumb as it sounds, it's not a Pontiac that rotates counter clockwise. Are you lining up the mark on the harmonic balancer with zero on the timing tab??? Without having #1 spark plug out and feeling for that pop on the compression stroke, then it's 50-50 of getting TDC. If you're unsure, easy enough to pull the distributor out enough to disengage the distributor gear, rotate 180 and drop back in.
BTW...we need to stop perpetuating that old wive's tale...you can have zero oil pressure/no oil in the oil pan and the engine will still start. Oil pressure switch is a backup that allows the fuel pump to energize in the event of the fuel pump relay failing.
Old May 21, 2023 | 04:40 AM
mlm0's Avatar
mlm0
Thanks for the responses. You are correct, I was under the assumption that there had to be a certain oil pressure before the engine would start.
I still believe that my timing is off , but I have checked it over and over again. I put my finger over the number one spark plug hole while my wife cranks engine. When my finger gets blown off of opening I figure I am at TDC. I was using a tool the whistles, but I felt it was not as accurate as finger over hole.
Old May 21, 2023 | 08:33 AM
VikingTrad3r's Avatar
VikingTrad3r
Oil Producer
dont you need to be top dead center on compression stroke? not just have your finger get pushed off. That happens twice in 4 strokes but you need tdc at compression stroke
Tgen if you pulled the dizzy out its also really easy to be one tooth off due to the nature of the clockwise motion that the dizzy is turned as the drive gears mesh with the gears on the cam as its lowered into place
id say you are 180 off or a tooth off or both
Old May 21, 2023 | 12:16 PM
mlm0's Avatar
mlm0
thanks for responding. I think you are right about me not being on compression stroke. How can I tell if I am on compression stroke without removing valve covers?
Old May 21, 2023 | 12:27 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Remove the spark plug from any cylinder and place your finger on the hole. Have someone crank the engine over (coil disconnected) and you'll feel the pressure from the compression stroke for that cylinder..
Old May 21, 2023 | 12:58 PM
Jud Chapin's Avatar
Jud Chapin
[QUOTE=VikingTrad3r;1606649792]
"Good things come to those who wait, but only whats left by those who hustle"
Abe Lincoln
Old May 21, 2023 | 02:11 PM
VikingTrad3r
Oil Producer
rather than take the vc off, if you suspect the wrong stroke, rotate the rotor 180deg
i think thats right???
every time i do “timing” i need to refresh myself
Old May 21, 2023 | 10:15 PM
78blueta's Avatar
78blueta
When you feel the pressure it means your on the compression stroke but you still need to turn the engine by hand to get the timing marks lined up for tdc. Balancer mark should be at 0 degrees for tdc.
Old May 22, 2023 | 03:04 PM
mlm0's Avatar
mlm0
FIXED. Car is now running great!
Old May 22, 2023 | 05:28 PM
VikingTrad3r
Oil Producer
so what was it
Old May 22, 2023 | 06:39 PM
mlm0's Avatar
mlm0
I believe I just didn’t have my distributor cap properly lined up with the rotor so that the number 1 lug on the cap lined up with the rotor at top dead center. The last time i installed distributor, it still would not start, so i twisted the distributor main housing just a little advanced, and she started right up
To Need help, car won’t start
