last started in 2022 june
Old May 20, 2023 | 09:54 AM
signify's Avatar
signify
Default last started in 2022 june
what do i need to do on this new purchase to safely start after being in hibernation?
Old May 20, 2023 | 10:18 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
After first checking that all water hoses and belts look good and are in place, I'd change the oil & filter. Then I'd disconnect the coil and crank it over a few times to distribute the oil. Then I'd start it while keeping an eye for any water leaks or other problems. There are lots of opinions on this. I'm sure some would say just fire it up.
Actually, you are taking the seller's word that it hasn't been started in a year.
Old May 20, 2023 | 12:54 PM
billschroeder5842's Avatar
billschroeder5842
Zen Vet Master Level VII
Yeah, that's me. A year is not that long. Turn the key and let her rip.
Old May 20, 2023 | 06:47 PM
Incorvettei's Avatar
Incorvettei
Depends, what does the oil look like? Is it synthetic? How about the coolant? I don’t think I would try to start it without at least replacing the oil and filter
Old May 20, 2023 | 10:43 PM
C4 Steck's Avatar
C4 Steck
That time interval is not far off from typical winter storage time in the northeast where I live. Even with today’s ethanol fuel, you don’t have much to worry about. Some things I would do to a newly purchased car would help. You should change all fluids and filters anyway, especially the fuel filter. If you want to get really crazy, change the fuel filter and turn key to on with the fuel line disconnected at the engine. Let the fuel pump push any possibly contaminated fuel into a container before it hits the regulator/rails. A good coolant flush with the knock sensors pulled would be good. Clean the expansion tank and reservoir by hand if you like. Reassemble, fill, bleed, done. There are plenty of threads on coolant flushes and fuel filter changes. At under a year, gas should be fine.
To last started in 2022 june
