Engine trouble or normal??
Old Jan 17, 2003 | 11:36 AM
redvetteC4's Avatar
redvetteC4
Default Engine trouble or normal??
My car idles pretty good and accelerates very well but if I suddenly let off the throttle and let it decelerate i get a slight twitch or shimmy. I can not even tell where it is coming from the front or back end. It is not really bad I mean when I have a passenger in the car and ask them about it they say they really don't notice
Old Jan 17, 2003 | 11:49 AM
secondchance's Avatar
secondchance
Default Re: Engine trouble or normal?? (redvetteC4)
I would check all ball joints and suspension bushings. Although I have never had similar problem, it almost sounds as if suspension geometry is shifting when forward thrust is reduced.
Its worth a try.
Old Jan 17, 2003 | 11:53 AM
scorp508's Avatar
scorp508
Does it feel like the back end hit ice for a millisecond? Check your wheel bearings for play and your tie rod ends. :)
Old Jan 17, 2003 | 12:57 PM
redvetteC4's Avatar
redvetteC4
Default Re: (scorp508)
I live in Texas and only wish I knew what driving in ice was like (seems fun but dangerous) :D . It is really hard to pinpoint exactly where this irregularity is coming from. Do I need a jack to check the wheel bearings? The suspension is without a doubt the most unfamiliar part of the car to me. TIA
Old Jan 17, 2003 | 01:23 PM
chucks88's Avatar
chucks88
Default Re: (redvetteC4)
That is the same symptom I had when my bearing was found to be shot. You can get your rear wheels off the ground, grab the wheel at 12:00 and 6:00 and rock it to see if there is any play. There shouldn't be any.
You can do the same thing to the front tires but I suspect if it is a bearing it's in the rear.
Chuck
Old Jan 17, 2003 | 02:37 PM
redvetteC4's Avatar
redvetteC4
Default Re: (chucks88)
Thanks for the reply...I will check it as soon as its convenient. How is long it safe to drive it like this if it is barely noticable?
Old Jan 17, 2003 | 03:02 PM
John Row's Avatar
John Row
The smartazz answer is "It's safe right up to the point it goes out completely".
I think the answer you are looking for is drive conservatively and you can go a long way. That said, it's best to fix it sooner than later.
Old Jan 17, 2003 | 03:13 PM
vader86's Avatar
vader86
If you arent hearing any noise from the bearings, you could probably go a couple hundred miles more.
But if they do go, youre screwed. The wheel can just FLY OFF.
To Engine trouble or normal??
